HID Headlamps
Old May 11, 2020 | 02:05 AM
Andres V. Pessoa's Avatar
HID Headlamps
Hi Mustang Fans! I have problems with my HID right Headlamp, it was working and then not, I used my car again and it work but now it does not work anymore. I bought a new D3S Xenon Bulb change it but it is still doesn't work. What can be happening? Can someone maybe help me? Do I need to check the wired and the Fuses? I have a 2017 GT/CS Mustang
Thanks in advance.
Old May 11, 2020 | 08:38 PM
houtex's Avatar
Probably the ballast. The HID bulbs require a module called a ballast that ignites and drives the bulb. Similar to a florescent shop light.
https://www.google.com/search?q=2017...llast&tbm=shop
They're wildly all over the place on pricing. Of course, being in Germany, you probably will have a more fun time acquiring it.
That's not a guarantee that this is the problem. It just seems most likely given the intermittent issue, and the second bulb not likely having failed, unless the ballast killed it.
You might can swap your right and left ballasts and see if the problem moves, thereby verifying the ballast being bad. Maybe a little troublesome to do, but you probably should test it somehow before buying anything, right?
Hope that helps!
Old May 12, 2020 | 12:26 AM
HID Headlamps
hey man thank you very much. I will check that out and see if I can find something.
About the funny Germany part you've the right haha Pura Vida!!!
Old May 13, 2020 | 07:49 PM
houtex's Avatar
Yes sir, glad to be of service! Good luck!
brasil
05-09 Exterior Modifications
Oct 8, 2019 05:33 PM
catlover1982
Aug 30, 2014 03:39 PM
slayerkw
Jun 8, 2014 04:57 PM
Mralternation_
Jan 6, 2014 09:15 AM
