Helpp! '66 coupe
Old Apr 8, 2013 | 12:15 PM
cam94's Avatar
Helpp! '66 coupe
Hey guys i really need some help!!! Im considering buying a '66 mustang coupe GT. Its an automatic, factory A/C, and front disc brakes. It has 55,000 miles. The guy i would be buying it from knows the whole history on the car. True cali car, with very minimal rust. 2 owner. The guy started telling me that this car could actually be a golden annyversary edition and if that is the case it could be worth a ton of money. I did some research and found out that the only way to tell if it is truly a golden annyversary edition is a tag that would have been on the inside of the front fender... Only problem, there is no front fender... So i was wondering is there another way to tell? Plus what would the value of the car be if restored?
Old Apr 8, 2013 | 06:30 PM
No front fender???!?! Then that car is not what he says it is. If I owned that car, it would be "exactly" the way it came from the factory. But, that's just me. Good luck!
Old Apr 8, 2013 | 07:53 PM
houtex's Avatar
The records are gone, unless he has that particular onion skin, due to the Rotunda fire. That's why the Mustangs from '67 and back can be faked in so many ways.
There really is no way to tell. Therefore it is nothing more than a regular '66 Mustang, and you should treat it as such unless proven otherwise, and I mean ironclad proof.
Old Apr 9, 2013 | 04:42 AM
jsimmons's Avatar
If he can't prove it's a golden anniversary car, then it isn't one. Are you absolutely sure it's even a factory GT? Look at the 5th character in the VIN - it should be an "A" or "K" ("K" is the more desirable of the two). Since the car in question is an automatic, it's probably going to be an "A" code car.
The steering box should have a tag with one of the following codes - "HCC-AX(MS)" or "HCC-AW(PS)".
If it's a golden anniversary car, it can't be a GT, because all the golden anniversary cars were "C" code cars (2bbl 289, automatic, gold metallic paint, black pony interior), and only about 50 were made (one for each sales office at the time).
If it were me, I'd hope it was a GT instead of a golden anniversary car.
Old Apr 9, 2013 | 05:59 PM
cam94's Avatar
Thank you all for your help! Im doing more research on the car, may be coming back for more info!
CiniZter
25
Apr 28, 2016 05:41 PM
FromZto5
75
Oct 5, 2015 02:27 PM
Sep 16, 2015 06:44 PM
