Help with a "Special Needs" Passenger...
I have a passenger in the Mustang that needs to be re-located from the passengers seat to a new "home" in the vehicle:
![](http://img22.imageshack.us/img22/6301/8zle.jpg)
(aka my free samples dispenser)
Before I go any further I will put this out there first. I carry the above firearm for my work everyday, so any time I drive the Mustang it has to be stored somewhere in the vehicle.
North Carolina is an open carry state, so right now I have 3 options:
1.)On my hip in its level 3 holster (also pictured above)
2.)On the passenger seat (in plain view)
3.)In the trunk
My card from the NCPPSB finally arrived after many months, so I can use my scores to get my concealed carry. This opens up me to storing the firearm anywhere in the vehicle. Only other issue is I am left handed, which is part of the reason transporting it in my holster on my hip doesn't work too well (door kind of is in the way). So does anyone have any experience mounting a holster inside a Mustang that is easy access but doesn't get in the way? I have some ideas but I wanted to get as much feedback as possible before dropping $$$ on a holster/mount.
3.)In the trunk
Trunk is out. I don't see why you would even have it, then.
In my work, I also need a gun handy, but not on my body. I've had good success with between the seat and the console; needs a holster for a Glock, though, because of the lack of external safety.
What I'd do is buy an el cheapo neoprene inside the belt holster and just put the pistol in it, then shove it in the space between the seat and the console. Being a lefty, you'd have to cross-draw, of course.
Is there a spot to mount a kydex holster under the dash, left of the steering wheel? All you'd need is to drill a couple holes, and you could get any composite holster of your choice to mount up there with sheet metal screws and washers.
BUT with my concealed carry I can start looking into other options obviously, and I like the idea of under the dash next to the steering wheel. That is actually the idea I was kicking around in my head today. I didn't think of between the seat and console, but it is something I will take a look at next time I am in the Mustang. Keep the ideas coming, I am sure there are a good number of places to fit a holster (while still being accessible) in the stang.
Carrying it on you all the time can get too challenging mentally where you can't relax. Being on your guard 24/7 gets taxing. Been there, done that. Others are perfectly fine with carrying it. Depends on your own personal make-up. I stopped after awhile and started enjoying life again. As long as you have the permits, keep it handy 'just in case'. However, the passenger seat is too 'out there' IMO and any 'lefty' in a taller vehicle that can look down into your Mustang will call the cops and give them your tag number. They might even say you are waving it around because they are so anti-gun. They despise gun owners. You don't need the grief. Use whatever works for you. We are all too different on comfort levels.
** By the way, your title would probably get you 'profiled' by the politically correct crowd. Who do you think your are, Larry the cable guy? LOL!!!
Not a bad idea depending on your goal/priorities in storing the firearm. But for me putting it in the glove box would be similar to keeping it in the trunk (no direct access). Again that is just me, different options work for different people. I considered the Beretta 92 and 96 when I was looking at duty weapons, but ended up going with the Glock. (Still great guns though).
Carrying it 24/7 can be taxing, but I all ready carry it 12 hours a day while on duty 5/6 days a week so its not too bad. The passenger seat is 'too out there' also in my opinion, that is why I am getting my concealed to put it somewhere else not in plain view but still with easy access. Trying to get ideas from other's on here where to mount a holster in the Mustang.
As far as the anti-gun people go, I figured the title was a little more low key that saying "I need a place to store a Glock in my Mustang". And hopefully they can understand I have to carry it as my duty weapon for work (making transportation a legitimate issue).
You know what be cool? A special docking station where the entire holster can be clipped underneath the dash next to the steering wheel.
The safest bet with a firearm is to keep it in its holster; the great majority of NDs happen when pulling an arm out of the holster and putting it back in. So why not short cut the process and leave the gun in the holster? It would work for paddles and "J" hooks.
All you would need is a "U" channel the depth of the holster and the width of the paddle. Drill a hole on each ear of it and use sheet metal screws to hold it to the dash. It would retain the holster and allow the pull to draw. The paddle would go down, or the "J" hook would go up, with the "J" hook retained by the edge of the dash.
I have seen pics of holsters mounted under the dash, right under the steering wheel. Seems it would be the best bet for you, especially being left handed. Are you a state trooper?
One more thing: Ditch the Serpa. They are pretty much junk, and unsafe to yourself and others to boot. Safariland makes a very competent kydex holster. Heck, even a cheap Fobus is better. The cheap Serpa retention button will fail when you need it most, and if you are lucky, it won't cause you to shoot yourself by accident.
http://www.texascustomholsters.com
very easy to install and very secure no wiggling at all
Her name is Chrissy
Thank you everyone for the suggestions, I all looking at everything that has been posted. When I do get something setup I will make sure to post pictures.
I hadn't heard of anything bad concerning the Serpa, but after reading your post I looked into it a little. Seems like it is possible to have a ND when drawing your weapon if you put your finger inside the trigger guard. When I pull my Glock out of the holster my trigger finger falls in line with slide above the trigger guard, so I haven't experienced that issue. I will take it into consideration and look at other holsters in the future, but right now the Serpa is working well for my use.
Having said that, I still have one Serpa that I only use for low stress situations with one gun, mainly because I'm too cheap and lazy to get something different.
I know I've seen an el cheapo Uncle Mike's holster that straps onto the bottom of the steering column somewhere, but a google search comes up empty for me.
If you're on Facebook, "like" Glock Girl, and she has a rig like that.
Texas custom holsters...
![](http://cdn.shopify.com/s/files/1/0196/1804/t/1/assets/carousel-item-2.jpg?663)
Location: the beautiful "Shenandoah Valley of Virginia"
Been carrying on and off duty since 1978 ..... feel naked without, feel perfectly at ease with it on my person.
I have Sigs that I carry in holster rigs, but sometimes I carry a Ruger 101 2" .357 bobbed hammer DAO in a pocket holster or ankle rig inside left ankle (for easy access sitting .... I'm a righty). There have been some few times when I was having a bad back day and simply tuck a sig under my right thigh inside it's holster.
I've worked a few wrecks where an unsecured weapon was lost or found later alongside the roadway.
Also, if approached by an on duty .... consider doing the polite thing of declaring it.
