fuel injector problem
after a engine rebuild the #6 fuel injector stays on once the key is turned on
the engine did start and run but the cat got hot
any one with an idea other than the computer?
also a source for a computer would be appreciated if the worst has happened
thanks
allen
1994 MUSTANG V6 5 spd
need a computer
95 will also work
any help appreciated
allen
more info
this car had #6 fuel injector stay on
the solution: replace the computer
it is now running great with a rebuilt engine
it has 140k
the engine required
new cam
rings bearings and oil pump
head refurb, vatting of block
new clutch bearing and pressure plate
machine flywheel
everthing else was within factory tolerance
cost to put back on the road was $1100 dollars
v6 new genaration engines are expensive to build
thanks for the help
i recieved many sugestions
allen
thanks
allen
need a computer
95 will also work
allen
more info
it has 140k
the engine required
new cam
machine flywheel
thanks for the help
allen
Rando
8/25/21 11:12 AM
