Dimmer module NOT req'd for Autometer Elite gauges...
Old Mar 21, 2012 | 07:50 AM
soltic's Avatar
Since I couldn't find a Tech section I figured I post here....
Re: the Elite gaugues, u DO NOT need the dimmer hardware.
I installed the Elite gauges thru a very well known Mustang modifier here in Ontario, Canada (DaSilva Racing).
They did the install according to instructions & hooked up the white wire which allows dimming - however if u program the gauges to be dimmable according to instructions - they will be dimmed (setting by regular headlight dimmer) when headlights oin but will not light when the headlights are off (or in DRL mode for Canucks).
I did not know this & did not order the dimmer module & after trying to drive @ night in "Full ON" mode w/ what seemed like 3 flashlights pointing at your face (& illuminating the backseats incredibly well), got pissed when I found that I apparently needed the module.
So I called Autometer Tech & the first fella more or less told me tough luck - if I didn't want the dimmer from Autometer that I could buy another manufacturers.... oh & that it was well known that LED gauges need a dimmer module...
This didn't sit well w/ me so I called back & got an appropriately educated Tech person.
Short story long, the new Elites have firmware in them to allow dimming w/out the dimmer module.
Power up holding the right / Peak button, press again to show white illumination / Full-On, press Peak again and hold, & press and release Warn / Left button to program dim setting.
Has 4 dim levels.
I run lowest.
No need to spend $ on the dimmer, I guess their lack of updating instructions simply is making them $.....
Glad to have called back & met a decent Tech chap.
Guess my ignorance in not oredering the module paid off.
Hope to save someone $ who doesn't know.
-Rod
Old Apr 5, 2012 | 02:46 PM
Scruffy281's Avatar
What is the deal with the Blue/Orange 'Pro control' wires on the gauges?
I was under the impression that it installs like a normal gauge. Sender -> Gauge, 12v, Ground, Illumination, etc. Then the gauge itself can be set on the high/low warning. How does it work?
Thanks!
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
kennyg
Aug 14, 2023 11:45 AM
poldrv
Aug 18, 2015 06:42 AM
Jul 30, 2015 06:47 AM
