c4-c6 converter question.
Old Sep 25, 2013 | 03:38 PM
pricanclaudio's Avatar
Hi guys how I have a 89- 5.0 fox with a c4 , I have also a 10 inch converter that lines up against flexplate holes , bin told it was for a c4 but it requires a thicker in put shaft thsn the shaft thats in my c4 , any way of confirming if its for a c6 without any part number or company name.
Old Sep 25, 2013 | 03:45 PM
HOSS429's Avatar
legacy Tms Member
it`s been a while since iv`e seen either but i`ll give it a try .. the C4 will of course have a much smaller input shaft ,, about 3/4 inch dia. i think .. the C6 shaft will be about 1 full inch .. if you have a C6 convertor that fits a C4 trans it should be two different sizes..smaller on the end that fits the trans pump than the convertor ..i dont see the need in such a convertor ...
Old Sep 25, 2013 | 03:52 PM
I agree I just found on ebay a sleave adaptor that allows you to install a c6 converter on to a c4 tranny for about 60 bucks , its cheaper to pay 60 instead of 300-400 bucks for another converter. And I just need to find a way of finding out if it is for a c6 since I dont have a c6 input shaft that I ca n put in to it to confirm it is a c6 converter that I have.
Old Sep 25, 2013 | 03:59 PM
HOSS429's Avatar
legacy Tms Member
i have a 4500 C6 stall out of a car .. i will try and measure it ... give me a minute or two >>.
Old Sep 25, 2013 | 04:00 PM
Thanks bud
Old Sep 25, 2013 | 04:09 PM
HOSS429's Avatar
legacy Tms Member
the pump hub diameter is just under two inches .. it may be the same for a C4 and a C6 .. the C6 input shaft is just over one inch .. i`m quite sure a C4 shaft is much smaller ..... now that i dwell on it i remember putting a C4 stall convertor behind a 429 C6 trans once .. i had a custom shaft made ... it did`nt last one pass ...
Old Sep 25, 2013 | 04:21 PM
Cool thanks for the input....
Old Sep 25, 2013 | 04:23 PM
Maybe 429 to much for c4 converter thsts why I was hoping to put c6 converter ca use I figured it had to be stranger in c4
Old Sep 25, 2013 | 04:26 PM
HOSS429's Avatar
legacy Tms Member
contact someone at perhaps B&M convertors ... they surely can help you ...
Just the opposite
Old Sep 25, 2013 | 04:49 PM
HOSS429's Avatar
legacy Tms Member
Just the opposite
so yes .. it can be done ... i did`nt have my custom shaft heat treated .. that may be why it twisted into ..
Autotooner
Nov 24, 2017 12:42 PM
yabutt
Oct 23, 2015 01:05 PM
mlcinema
Oct 7, 2015 10:05 AM
50Cal
Sep 16, 2015 03:54 PM
