Brenspeed Reviews JLT Oil Separator; ITS AWESOME!
Old Nov 9, 2010 | 12:59 PM
BRENSPEED's Avatar
JLT Plug & Play Oil Separator:
For a long time now we have been selling and installing Oil Separators and although they worked well we never felt they fit the engine compartment like a lot of the OEM looking parts we sell. Most companies make a separator that has a canister with a lot of rubber lines and clamps that allow you to choose the location of the separator mounting. This leaves you at times with a “rats nest” appearance in the engine compartment. JLT has released the most OEM looking plug and play oil separator we have used yet.
Oil Separators serve a basic purpose. In short they capture oil that may be trying to work its way through your crankcase venting process. Why do you want to capture this oil? Oil in the intake can cause many issues. A few of the popular ones are it can come to rest in your throttle body which many of you know causes idle issues on S197 Mustangs. It can coat your intake manifold, work its way into the rotors of your supercharger, clog your intercooler fins, and dilute your gas octane level. This can cause detonation which can in turn cause engine damage.
The new JLT oil separator comes with OEM lines already attached so you can simply plug it into existing vacuum ports. Total install time is faster than you have read this article. The new oil separator is machined from solid billet aluminum. It has a knurled tank base for easy removal and uses a Ford Motorcraft metal mesh PCV pre-filter element. According to JLT this element collects the last bit of oil droplets and drains back into the tank when the engine is shut down. The tank holds 2 oz. of fluid and will hold enough oil to only need checked every oil change. The tanks are available in anodized black or anadoized clear coat satin finish.
We get a lot of new products in every year and this is for sure one of the coolest. Hope you found this info helpful as it is a very nice piece. If you have more questions we didn’t answer don’t hesitate to give us a call at 574.594.9559 we will be happy to help. These plug and play separators only retail for $119 including the OEM Ford Lines already attached. More information and pictures of these can be found at the link below.
http://www.brenspeed.com/05-08-mustang-fuel---induction-oil-seperators.html
Old Nov 18, 2010 | 11:50 AM
SD6's Avatar
SD6
Forgive me if this is a dumb question, but does this work for 2011 Mustangs also?
The link that was provided to your page only states 05-10 Mustangs.
http://www.brenspeed.com/05-08-musta...eperators.html
14Glassback
Oct 4, 2015 08:52 AM
RoushRS3
Sep 29, 2015 08:03 PM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
SterlingStunner
Sep 16, 2015 12:30 PM
