8.8 pinion bearing
Old Jun 29, 2017 | 11:57 AM
Rg3's Avatar
Rg3
8.8 pinion bearing
So I was cutting off the pinion bearing and put a gash in the pinion shaft. Will this affect anything?
Old Jun 29, 2017 | 10:34 PM
Rg3's Avatar
Rg3
Thumbs down
Nothing?? Thanks for the help guys
Old Jun 29, 2017 | 10:39 PM
HOSS429's Avatar
legacy Tms Member
i would not be concerned with a small gash .. you still would have 98 % of a good surface ..
Old Jun 29, 2017 | 11:02 PM
Rg3's Avatar
Rg3
The new pinion bearing will cover it once its pressed back on. Any thoughts of it being of balanced or bearing failure?
Old Jun 30, 2017 | 05:45 AM
pics of your gash??
Old Jun 30, 2017 | 08:47 AM
HOSS429's Avatar
legacy Tms Member
it has such a small spin radius i would not be concerned with balance .. i have yet to see evidence of balancing on any ring and pinions i have installed over the years ...
Old Jun 30, 2017 | 11:20 AM
Rg3's Avatar
Rg3
Old Jun 30, 2017 | 11:22 AM
Rg3's Avatar
Rg3
Not pretty.
Old Jun 30, 2017 | 11:29 AM
ElkGroveFordGuy's Avatar
I would reuse it!
Will probably never affect anything.
Old Jul 1, 2017 | 08:14 PM
2014GHIGGT's Avatar
It will be fine. Although I am curious why you were cutting the bearing off??
How are you putting the differential back together?
Old Jul 7, 2017 | 09:45 PM
Lime GT's Avatar
just make sure you remove any rises/burrs before reassembly
Old Jul 8, 2017 | 01:40 PM
I would hope its back together by now?
