302 rocker arms
if you have something other than stock you can certainly create an issue ..though i`ve not heard of push rods bending to the point of breaking . something big is going on ..coil spring bind if you have too big a cam on stock type springs .. lifter over pump up if you have a hi volume/ pressure oil pump . valves actually contacting the pistons at high rpms..though the valve usually loses in that case ..too long of pushrods if you are non stock .. to tight of valve adjustment if they are adjustable ..
JonsMustang
12/9/20 08:54 AM
DerekShiekhi
7/19/16 11:05 AM
