07 mustang puddle light help!!
For the cleanest factory looking installation, the secret is you have to dismount the rubber wiring conduit from the door hinge pillar. Where the rubber conduit meets the hinge pillar it snaps in a certain way that is tricky to disengage. It's a tight space to work in but it can be done. That exposes the door to body wiring connector.
You have to start by running the wire from inside the door into the rubber conduit. Then you pull the wire through the rubber conduit. Next you have to fish the wire into the space around the perimeter of the door-to-body wiring connector. The wire should drop down into the kick panel area of the interior so you can pull it to where you want it to be.
Once you master doing one side, the other side installs much faster.
Michael Follett
7/24/15 06:58 AM
