Sweet forum app!! Little help with some back firing in the upper intake
Old Apr 28, 2012 | 11:51 PM
cszentes's Avatar
New here I have a 89 5.0 H.O all pretty well redone. Just finishing up the motor with a complete block tear down and now with the new cam and new upper and lower intake I'm getting a lot of backfire in the upper intake any one deal with this before?
Old Apr 29, 2012 | 12:00 AM
AlsCobra's Avatar
A Man Just Needs Some....
Firing order or timing issue.
Old Apr 29, 2012 | 10:05 AM
Boss 1409's Avatar
INKY
Welcome!
Old Apr 29, 2012 | 10:12 AM
lalayla's Avatar
Calgon Take Me Away!
Welcome
Old Apr 29, 2012 | 11:08 AM
welcome from me too. Maybe a couple of plug wires in the wrong place?
Old Apr 29, 2012 | 02:44 PM
skunk21's Avatar
+1 popping thru the intake 99% of the time is one of these. oh and welcome.
Old Apr 29, 2012 | 07:25 PM
cszentes's Avatar
Thanks a lot. Will get some pics up soon.
Old Apr 29, 2012 | 08:04 PM
ford4v429's Avatar
legacy Tms Member
with a aftermarket cam, might verify firing order is same as before too- IIRC the windsors had two different firing orders available depending on the cam.
if not a firing order issue, run a quick compression test to look for a open valve- maybe lash on a intake was set too tight.
Old Apr 29, 2012 | 08:46 PM
cszentes's Avatar
Checked with crane on the cam also checked compression all numbers were 170, 180. These are awesome suggestions keep em rolling I appreciate all of them.
Old Apr 30, 2012 | 07:55 AM
skunk21's Avatar
well since you checked the obvious ( tight rockers, timing, firing order) you could have faulty o2 sensors causing a lean condition. also since you just did a motor on this go over all your wires, connections and vacuum hoses and make sure they are all connected, very easy to miss one when doing a big job and having a sensor disconnected can cause problems also.
Old Apr 30, 2012 | 01:21 PM
cszentes's Avatar
Finally got a profile pic up anyways. Thanks for the advice will try it and get back to you.
Old Apr 30, 2012 | 06:42 PM
cszentes's Avatar
Well now it won't start. Possibly the ignition module??? So frustrating just want to drive!!! Any suggestions?
Old May 1, 2012 | 07:05 AM
skunk21's Avatar
time to start a thread over in fox section since this is intro and so we can spend some time on it. also in the fox section we have a tech thread there is a "crank no start" help thread I have in there you can read.
sarnold58
Jun 9, 2019 02:22 PM
Bullitt 3309
Aug 2, 2015 10:20 PM
