ford 302 85 msd igniton and edelbrock intake and carb problems
Old 3/1/15, 09:20 PM
irishfire101's Avatar
Just got all the work done timed it at 12 degrees and can't get the thing to idle for Me for a long period of time. It is a mechanical distributor. I have the firing order correct. Also when it does idle its rough and drops when I hit the gas unless I slowly go down and increase throttle
Old 3/1/15, 09:45 PM
Jazzman442's Avatar
Vacuum Leak? Electronic ignition?
Old 3/1/15, 09:55 PM
I checked for leaks did not find any, and it was a kit that came with everything. I'm thinking maybe the timing is off I have mid grade gas in the tank. Is there an easy way to look for leaks I may have missed
tdf017
8/5/15 10:13 AM
MADSCOTSMAN
7/22/15 04:57 PM
Quick Reply: ford 302 85 msd igniton and edelbrock intake and carb problems
