Garage door opener hell....help me!
Old Aug 11, 2006 | 07:36 PM
rocket88's Avatar
So today I go buy a new garage door opener, no more getting out of the car to open the **** door! Install takes all of 30 minutes, all I have to do is line up the stupid sensors. I run the wires & sensors to each side of the door and I can't get anything. I move the sensors to within a foot of each other and I cant get anything. I figure there has to be a short in one of these wires so I shorten them to about six inches each, hook them back up and nothing.
So obviously I can order new sensors, and the opener still works, you just have to hold the button down while it closes which is annoying as heck. but I don't really care to have them anyway, they're always getting bumped and what not, so is there any way that I can bypass the stupid things?
Old Aug 11, 2006 | 09:30 PM
MY05GT's Avatar
Are the sensors lighting up? I got the top end of the ones Home Depot sells ( Genii ) and I have an L.E.D. on each sensor ( one red, one green ). Also, try it at night to make sure you do not have "light polution". If that works, you may need to move the sensors farther from the door.
Old Aug 11, 2006 | 09:40 PM
rocket88's Avatar
I get one that lights up (one transmits, one recieves) and the one that recieves will light up at times but not consistantly.
Old Aug 11, 2006 | 09:46 PM
I taped mine together and hung them up on the opener.
Old Aug 11, 2006 | 10:12 PM
karman's Avatar
That'll Work.
Old Aug 12, 2006 | 01:04 AM
rocket88's Avatar
yeah i tried that, no luck!
Old Aug 12, 2006 | 06:29 AM
I would say there is a wire hooked up wrong or you have a falty part some where then
Old Aug 12, 2006 | 01:01 PM
korinwoodo's Avatar
is there a wire coming out of both of them? I would just cut the sensors off and complete the circuit.
Old Aug 12, 2006 | 10:16 PM
MY05GT's Avatar
I would not recommend bypassing this safety feature, take the time to figure out the problem. Make sure you are wired correctly. If you have a Genii, make sure the green LED stays on. If the red LED is blinking, it is not seeing the other sensor.
On mine, the wiring at the motor could have been a little more clear, check that. Based on what you have said, I would suspect a loose connection somewhere with the second sensor (or even a bad sensor) or the sensors are not lined up right. Again, try this at night or with the door closed.
Old Aug 17, 2006 | 06:00 AM
did you get it going?
Old Aug 17, 2006 | 07:25 PM
rocket88's Avatar
I bought new sensors, works like it should.
kponypower
Jun 17, 2020 07:17 AM
RCooke08GT
Feb 19, 2017 03:03 AM
Sep 30, 2015 07:02 PM
