Neat Trick To Change Steering & Brake Fluids
I read this awhile back and thought I would share. Every couple of years you should replace your steering and brake fluids. Pick up a couple of meat baster and label them brake and steering. You can use them to remove the fluids from the reservoirs.
great idea
I also read in Car Craft a neat little trick on how to use your air compressor and to build a $5 part to bleed the brakes yourself
get a flat plate of steel large enough to go over the opening to the master cylinder resivoir. Drill and tap a hole in the middle for an air fitting, and have the opposite side covered with a stick-on gasketing material. Fill the m/c up, strap that guy on, set the compressor at 30PSI and you can bleed the brakes yourself
great idea
9/8/15 10:45 AM
