310 rwhp
I depends. Losses from the flywheel to the wheels vary depending on the efficiency of the drivetrain. Automatics tend to stink up a bit more power than manuals and the overall losses vary from model to model.
The rough rule of thumb I've read is around 12 - 15% loss for manuals and 15 - 20% loss for automatics, but individual results may vary.
Using the 15% loss figure, 310 RWHP would convert into 356.5 flywheel horsepower.
Keep in mind that the SAE net standard automakers use is also done at a consistent temperature and tightly controlled proceedure, so comparing an individual RWHP test, under different conditions, converted to flywheel horsepower, will only give you an approximate number for comparison.
9/16/15 06:44 PM
