'13 battery & weight balance Qs
Old Apr 12, 2012 | 07:49 PM
wheelman's Avatar
I'm adding some electronics which require backup batteries to a '13 and was thinking, so I don't have to check/replace multiple backups and I so I don't put too much load on the OEM battery, to just run a second 12V battery as the backup for everything and stick it in a box in the trunk, like you would if relocating the battery. I'm only 175 so I figure 40 extra pounds ain't bad and I'll lighten the car a little somewhere else. The car will see track time, but will be a DD. Am thinking of buying a battery relo kit and powder coating the box. I just need to wire + to + and - to -, right? And I'm guessing it should go on the d/s, correct? I figure that's opposite the primary battery and the d/s should be setup better for more weight. No idea what the weight balance is front to rear and d/s to p/s on 10+s, though. Anyone else? And any issues I haven't thought of or anything else I should consider?
Old Apr 13, 2012 | 08:34 PM
Automagically's Avatar
Are you using an on board compressor? Quick guy handy man service. Please explain why you would need any type of battery back up and using the car as a track car. I'm really not trying to sound mean but it isn't a jet. Just trying to figure out the necessity and how you can avoid the weight or even the load on the electrical system.
Old Apr 14, 2012 | 08:43 AM
wheelman's Avatar
Always thought would be cool, but no.
Security upgrades, so not really going to get into specifics and as I mentioned, it will be a DD that will see some track time. It's not going to be a track car. Was just trying to give as much info about the car's use as I could up front.
I'm adding a battery, not a turbine! Without getting into specifics, if you have two power sources in two different, locked, locations, its going to take a thief that much longer to stop an alarm and anything else tied to it, like notification services. Note that the active-anti-theft comes with a larger battery already, to handle the constant monitoring when armed I imagine, so I don't want to add more security/monitoring and overdraw the battery when the car is off/armed or overtax it under load when I add audio/video upgrades, performance alternator or whatever down the road. Don't know a great deal about electrical, which is why I'm asking Qs here.
EDIT: P.S. I guess what I'm really looking for is a low-maintenance battery backup. I don't want my car to get jacked cause I forgot to check my backup batteries that month. With a 12v backup, I can check it like once a year and Ill know if/when there are battery issues.
Old Apr 14, 2012 | 09:28 AM
wheelman's Avatar
...but Im also interested in the weight balance of the car if anyone has info.
Uofmrampage
Aug 2, 2022 02:55 PM
lakersfreak
Jun 13, 2022 12:29 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
PonyMuscletang13
Sep 24, 2015 01:40 PM
Sep 8, 2015 10:45 AM
