First oil change
I have an appointment for my first oil change next week (5700 km) and I have talked to the guy at Ford service about an annoying sound between 90 to 80 when the car deccelerated...
I think I have seen a topic previously about that in the general forum ?!?! Since I am not coming here to often now... Somebody has info about that issue with some of the GT 05 ???? Its not so bad but I am now focusing on it and I hope they will be able to correct that. :scratch:
I think it must have something to do with the gear and pinion, where the two meet, you sometimes get that annoying noise when decelarating, as to know if it's normal or not, i suggest that you bring the car to the dealer......my 5.0 has done that for a while after i did a gear swap....it 's a bit normal for the gear to do that when it's new as it takes a bit of driving for the gears to to mesh perfectly...let us know what they say......
Mary, je part pour Cuba demain matin et reviendrai dimanche prochain, aussitot revenu, je ferai une rencontre souper pour le début Mars.......j'ai été trop occupé ce mois-ci, alors je récidive pour Mars......
A bientot.....
Originally posted by Galaxie@February 12, 2005, 7:32 PM
Apparently there is a TSB on gear noise.
Have them check it out.
Galaxie, sorry for my ignorance but what TSB means ????????
Originally posted by StangMary+February 13, 2005, 8:07 AM--><div class='quotetop'>QUOTE(StangMary @ February 13, 2005, 8:07 AM)</div><div class='quotemain'><!--QuoteBegin-Galaxie@February 12, 2005, 7:32 PM
[/b][/quote]
TSB = Technical Service Bulletin. Ford knows of the problem, and has come up with a solution.
Cheers!
No TSB on this issue...
They checked and everything met the specs.
I will have to wait until the summer to see if they will change everything because with the rain and winter tires... the sound was not enought loud to do something now... Will see.
For the moment, I can leave with that. As I mentionned previously, it's not so bad... with Rammstein, Slayer, Zombie playing in my CD player....
DerekShiekhi
9/30/15 06:59 AM
