Southeast Post Club or Event Information and Meet Stangers in Your Area
Track Rule Question
Old Oct 9, 2006 | 07:03 AM
S!CKB!TCH's Avatar
Track Rule Question
I have an 05 mustang gt with a few mods and i feel i might be close to or in the 12's. i think if your in the 12's then you have to have drive shaft loops? i dont, i got the stock driveshaft and no loops. i live in orlando and want to go to bithlo and run it. do i need a helmet, loops? i have nerver run it on a track so i dont know what to do? do i just go run and see what happens. help please, anyone going out on wed.? i've never been so help me out.
Old Oct 9, 2006 | 08:32 AM
Scothew's Avatar
Stubborn Bear
TMS Staff
Most tracks follow NHRA or NMRA rules. You can check out thier sites and see what they say. http://www.nhra.com and http://www.nmraracing.com
Also you can contact the track in question and see what they say.
Old Oct 9, 2006 | 10:38 AM
Burke0011's Avatar
Big Falken Tires
I know at Moroso in West Palm and the time I ran Orlando at FFW, I believe the current rule is in the 13s or lower, you need an approved helmet.
Drive shaft loop.... geez I don't think that's required unless you are going around 10s or something.....
What mods do you have on your ride? Automatic or manual?
Old Oct 9, 2006 | 01:48 PM
S!CKB!TCH's Avatar
Well Im Not Going To Be In The Tens But Here Are The Mods
Perf
4.10's, Frpp Shorties Ceramic, Pypes Off Road H, Flowmasters, Underdrive Pullies, Steeda Air Intake, Bamachips 93 Track Tune
Rims And Tires
Raceline Gt 18x9 With 255/45 Front
Raceline Gt 18x10 With 285/40 Back
Bfg Kdw 2
It Is An Automatic Also, I Believe It Is About 300-310 Rwhp, The Car Is Premium With Leather But W Shak 500, All Interior Pieces, And I Weight 160 Lbs. Should I Take Out The Spare When I Go To The Track? And What About Psi In My Tires, The Max Is 50, I Run Them At 40.
oh yeah i have eibach pro kit, bmr lca's w reloc bracts, panhard bar and brace.
Old Oct 11, 2006 | 07:42 AM
Burke0011's Avatar
Big Falken Tires
If you get multiple runs, run it at regular street weight.
Then if you want, take out the spare.
Also dropping the rear tire PSI to 35 might help a bit but do that after you get a base street trim run in like mentioned above above -
If you want, try to time it so when you get to the track, you have HALF a tank of gas or less.
On STREET tires, you don't need a serious burn out - just spin them a few times to clean them off. As you come into your lane drive AROUND the side of the water box (don't wet your tires - only with drag radials or slicks). Then line up center of lane in the grooves you see - back up a bit if you have to for your burn out but watch the water. You don't want to dawdle and hold things up but don't let anyone RUSH you - take your time so you get your run right. Powerbrake and bring the revs up till you feel the rear start to break loose - release break and keep on gas and spin them. Of course, stop before you hit the beams.
Get yourself set and creep up. When you break the first beam, WAIT and take a second. Both to get yourself ready and wait for the other guy if he isn't staged yet (with most racers, it is common courtesy to stage first light and WAIT for the other guy if he isn't prestaged yet)
Once you are both prestaged (first bulb), gently creep up watching the second bulb..... the second you see it lit, stop, hold the break down and bring the revs up - I ran Dougs tune in my 05 auto so power break to maybe around 1,700/2000 - you want the revs up but you don't want the car to creep.
ONLY WATCH YOUR SIDE OF THE TREE
Its easy to get distracted watching the other guys side.
First amber light will go on, then second, and then the third. Watch for the third one to dim and go out - release the brake and mash the accelerator to the floor. By the time you roll across the line the green light should be on.
Keep pedal down and hang on!
Perf
Rims And Tires
Bfg Kdw 2
Old Oct 12, 2006 | 08:37 AM
S!CKB!TCH's Avatar
well i still havent made it to the track but i like your bulb tip and info. very good advice. but there's no way i could rev mine to 2 k, when i let go i'd be peeling out, i got 4.10's. when i prat drag on a remote street, i smash it and manually short shift the auto into sesond at 4k. otherwise it peels out way too much. man i want a time slip, i will make it down there soon, i hope.
JTB
Motorsports
Oct 29, 2015 09:07 AM
Feffman
Sep 28, 2015 06:46 PM
Feffman
Southeast
Sep 24, 2015 05:06 AM
Sep 8, 2015 10:45 AM
Cdvision
Sep 5, 2015 05:22 PM
