X2/X3 adjustable options
Can anyone tell me why, when I scroll through my adjustable options on the X3, most of them just have a rectangle with nothing in it...
But when I change the spark from 0-2000 to "0" degrees, other things seem to change. Like WOT Air/Fuel will read 580 revs/mile and spark 2000-4000 will read 665 revs/mile, yet they didnt have any #'s before.
Shift press (last option)..what is this first of all? all of them are set at -25%, but after I changed the spark as stated above, the shift press 4-5 read "10".
Obviously im not a programmer, so some might say, "dude, dont screw with it". I agree, but my problem is that for some reason the spark at 0-2000 was at "0", but somehow got changed to -14 degrees. What will this do and how will it make it run?
Can anyone tell me why, when I scroll through my adjustable options, most of them just have a rectangle with nothing in it...
But when I change the spark from 0-2000 to "0" degrees, other things seem to change. Like WOT Air/Fuel will read 580 revs/mile and spark 2000-4000 will read 665 revs/mile.
Its the X3 that I have, and im confused as hell right now. I have tunes from Bama and when I go to program tune a screen pops up and says:
Adjust Options
-Keep Previous
-Change
-No
Keep previous what?? If I hit "Change", it asks:
-Saved Options
-Default Options
Under the saved options it starts off by saying
Spark 0-2000
-14 degrees
Doesnt that sound odd (-14 degrees)?? And why would the shift pressure be at -25%. Again im no programmer, but the #'s just dont seem right to me.
Adjust Options
-Keep Previous
-Change
-No
-Saved Options
-Default Options
Spark 0-2000
-14 degrees
You should just answer no. The reason for that menu is in case you made changes in the past via user adjustable options, you can keep them.
As far as your setting being all whacked out...
That's why I don't sell it.
