Wind noise - suggested fixes?
Old Jun 28, 2007 | 07:10 PM
Dagwood's Avatar
I noticed the other day some wind noise coming from my passenger door (had the radio on mute for once!!!). Upon investigation today I discovered that the window is not sealing against the weatherstripping at the bottom of the window right above the door lock pin.
The gap between them is big enough that I can easily slide a business card between them as indicated in the first two pictures. By comparison, here's a pic of the driver's side which you can see the good seal as the card can't be inserted.
Anyone know of a way to fix this or do I need to take it into one of the local stealerships to get them to fix it?
Attached Thumbnails Wind noise - suggested fixes?-062807_17281.jpg   Wind noise - suggested fixes?-062807_17282.jpg   Wind noise - suggested fixes?-062807_17291.jpg
Old Jun 28, 2007 | 07:28 PM
Poco's Avatar
Try the dealship first. I had the same problem on a much older car.I took and replaced the weather stripping and to compensate for the gap along the whole strip I used a 3/8" manilla rope behind the rubber.I used the weather strip adhesive it never came off and the wind noise went away.The rope actually made the rubber buldge out just enough for a good seal.
Does the window raise up after you close the door? The door may be misaligned enough to cause that gap between your window.
Old Jun 28, 2007 | 07:56 PM
DoctorQ's Avatar
you might want to try the window reset procedure just to make sure the passenger window is correctly calibrated... this only takes a few minutes:
http://forums.bradbarnett.net/showpo...0&postcount=10
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Mr. V
Dec 24, 2016 02:57 PM
ricky1728
Feb 11, 2016 07:25 PM
