Wierd squeaking from rear end
Old Jul 16, 2007 | 06:29 PM
Reminisce's Avatar
Over the last month or so, I've noticed a very feint squeaking sound coming from the rear end of my car when going over bumps or whenever my car changes level going up a ramp or over a hump. It sounds like its coming from the rear driver side but I could be wrong.
I've never worked on the suspension on my stang, the suspension is 100% stock, so I'm not particularly sure where to look. What would you guys suggest I check? I'd rather do it myself and learn, than take it to the dealer. Thanks in advance.
Old Jul 16, 2007 | 07:44 PM
Rapture's Avatar
These are not quiet cars. My 93 T-bird rides smooth and quiet compared to my 07 GT
Old Jul 16, 2007 | 07:52 PM
ford4v429's Avatar
legacy Tms Member
take a look at your springs- the passenger side of mine was not installed right, the rubber 'pad' is pinched under the spring- noticed it when I was underneath undercoating(2 weeks old) meant to fix it just never got around to it...might be a common production line issue, and am suprised the spring isnt squeaking yet...
my car had a squeak last week, seat was fully lowered and squeaked like an old door- raised it a tiny bit off the stops and alls quiet...thought that was odd as the seat had been full down since the day I brought it home...
Old Jul 16, 2007 | 09:22 PM
ryan1112's Avatar
I have a squeek coming from the rear as well. The problem is that I have aftermarket exhaust, springs, panhard, and lower control arms. I have greased everything I can think of and it still squeeks. I'm thinking of putting lithium grease on all of the control arm bolts to see it that fixes it.
Old Jul 16, 2007 | 09:33 PM
RobK's Avatar
I'd start with the brake pads and go from there. Make sure all of the clips are in place and that pads aren't loose.
Old Jul 16, 2007 | 10:55 PM
Shelby10''s Avatar
you might also grease your drivers side Lower control are and see if that helps. My aftermarket LCAs sqeek the same way. Also when I get in and out of the car it sqeeks like your getting out of a bed haha. I need to get under there and grease those suckers
Old Jul 17, 2007 | 01:20 AM
awakeinAZ's Avatar
Could be the beloved differential squeal. Search other threads!!!
Old Jul 17, 2007 | 04:47 AM
WhoMe's Avatar
I have a creaking noise whenever going up and down driveways. I also expierence it when taking off from a stop very slowly and somtimes during slow turns. It seems slow exagerated suspension articulations bring it out. I never hear it when driving normally over bumps and the like. However unlike the original poster I do have aftermarket springs, LCAs, and panhard bar. This noise only started after the upgrades. I greased everything...I have a sneaking suspision its the springs or how they were installed. If anyone can clear this up I know I would appriciate it.
Fords4Ever
Oct 30, 2015 09:07 PM
seaclam
Sep 25, 2015 01:29 PM
1001yos
Sep 8, 2015 10:05 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
