Wheel appearance for the long term
I am undecided upon which wheels to order for my future Mustang. I like the 18" polished Bullitts the best, but I am a little concerned about how the finish will hold up over the long term. I would consider any of the four available GT wheels. I am curious as to how well all four wheels are holding up on your stang. Do you find that the finish is easily scratched or otherwise blemished? My previous experience tells me that painted aluminum holds up better than machined aluminum. I know it might be a little early to tell for the Fanblades and the 18" polished Bullitts.
All of the aluminum wheels are clearcoated, so the most important thing is how you take care of them. Most importantly, cleaning them on a reguar basis with a non-abrasive cleaner (I like to put a coat of wax on my bullitts). Keeping brake dust off them, and keeping from clanging the wheels off a curb are critical to their longevity.
Originally posted by dustindu4@January 4, 2006, 1:32 PM
Just don't drive those pretty polished wheels around during a Massachusetts winter
Originally posted by Boltzman@January 4, 2006, 2:14 PM
I have the blades and keep them maticulously clean,yet I'm starting to see small scratches here and there
![Roll](https://themustangsource.com/forums/images/smilies/roll.gif)
![Rollinglaugh](https://themustangsource.com/forums/images/smilies/rollinglaugh.gif)
![Rofl2](https://themustangsource.com/forums/images/smilies/rofl2.gif)
my bullitts seem to be holding up fine... they are cleaned regularly.
Now that I know how obsessive you are about your car, I am sure you will be fine. The polished bullitts do have the potential to show wear the most, but I am sure that it won't be an issue given the car will be taken care of.
I think the biggest error in today's typical fitment of tires to rims is that the rubber does not protrude beyond the rim. Hit one curb and you are buying a new rim! That is a pretty substantial penalty for a slight driver error.
With the stock 17"x8" Bullet rims, 255mm x 50% rubber gives you that little bit of safety cushion. With aspect ratio rubber that is lower (like 40%, 35%, etc.), over-shooting the width of the rim with the rubber becomes increasingly difficult. That is why I really like what I have on my Mustang. A nice classic 50% aspect ratio with a touch of budge not only gives you rim protection, but also keeps your replacement rubber costs down (my tires are $100 each).
The Chrome plating on my Les Schwab Rims is holding up perfectly (at least for the first 4 months anyway).
Alot of tires now are made with a rim flange protector. hehe technical name.
Its a thicker part of the tire made larger to stick out just past the lip of the rim.
The stock 18" BFG's have these.
![](http://zr1netregistry.com/497.12.jpg)
They are an alignment techs worst nightmare. Not allowing the aligner heads to crab the rim.
Originally posted by Boltzman+January 4, 2006, 2:14 PM--><div class='quotetop'>QUOTE(Boltzman @ January 4, 2006, 2:14 PM)</div><div class='quotemain'>I have the blades and keep them maticulously clean,yet I'm starting to see small scratches here and there
[/b]
[/b]
<!--QuoteBegin-Galaxie@January 4, 2006, 3:13 PM
[/quote]
![Topic](https://themustangsource.com/forums/images/smilies/topic.gif)
Originally posted by Boltzman@January 7, 2006, 11:40 PM
hey ray,do you know if chrome will hold up better than clear coated rims??
Originally posted by incomingRPG@January 8, 2006, 11:11 AM
My past experience with chrome rims is that they are very durable, easy to maintain, and don't scratch. I've had friends buy chrome rims that were clearly neglected with lots of surface rust, and as long as they were not pitted from the rust, they were easily brought back to new with a chrome polish. My only concern for you might be how, living in Tampa, the sand might affect things, but I would say look at the chrome bumpers on older pickup trucks as an example as to what to expect. I doubt it would be an issue, but in any case I would expect the chrome to hold up much better than clear coated rims.
Chuck, I was wondering how many miles you had on your car when you made this post...<div class='quotetop'>QUOTE(Boltzman @ January 4, 2006, 1:14 PM) Quoted post</div><div class='quotemain'>
[/b][/quote] It seems to me that I read somewhere that you have about 2000 miles on your car? Thanks for the help, I think that I might just order the stock bullitts and go aftermarket.
