Water Pump is Bad....Replacement?
Old Sep 27, 2012 | 05:42 PM
05PRMTX's Avatar
So I looked on ford parts and their pump is like $220. That seems obsurd when I can get one from autozone for $60. Is there any difference at all between them?
Old Sep 27, 2012 | 05:49 PM
one might be from china and the other might be made in America...check Napa auto parts and ask where it is made
Old Sep 27, 2012 | 06:07 PM
JerryG2163's Avatar
You could always look into getting a meziere water pump. That is an electric water pump and it actually frees up about 10 horsepower as it operates under the same principle of under drive pulleys. It is slightly more expensive at ~$300-350 but if your into modding it could be an easy way to kick it up a notch. There are plenty of threads on many forums detailing the install...
Old Sep 27, 2012 | 08:32 PM
antdog's Avatar
It also may be rebuilt.
Old Sep 27, 2012 | 10:57 PM
bob's Avatar
bob
Edelbrock makes one as well but its a belt driven pump (although you would have to determine if you have a long or short pump)
http://www.edelbrock.com/automotive_...igh_perf.shtml
163.00 bucks from Jegs (162.00 at Summit) and if such things matter, most likely made in the US at Edelbrocks own foundry.
Old Sep 27, 2012 | 11:45 PM
05PRMTX's Avatar
Thanks guys. I think Im going to check out the one from napa since they are close by and I need it asap (this is my only car). Hopefully its made here and I can get it installed tomorrow
Old Sep 28, 2012 | 07:20 AM
05PRMTX's Avatar
hey one more ? is this a DIY with basic tools? Im in an apartment w/ parking garage so I cant get too complicated.
Old Sep 28, 2012 | 05:58 PM
DaTT(1sK)'s Avatar
You will more than likely make a mess spilling coolant out. Have not done one on the S197, but typically they are a DIY'er kind of job.
Old Sep 28, 2012 | 06:50 PM
updates??
Old Sep 28, 2012 | 06:51 PM
it should matter to all of us
Old Sep 29, 2012 | 10:26 AM
05PRMTX's Avatar
Originally Posted by Glenn
updates??
Going to pick up the one from NAPA today. I looked into the company that makes it and they are a North American company. Also has a lifetime warranty. So I'm happy with its credentials considering I need it right away. Going to try the install this afternoon. Going to grab a big bucket for draining in an attempt to not make a mess lol.
Old Sep 29, 2012 | 05:57 PM
antdog's Avatar
I hope you remember the a new fan clutch while you are at it.
Old Sep 29, 2012 | 06:35 PM
fan clutch snot on our cars
Old Sep 29, 2012 | 11:06 PM
antdog's Avatar
Oops, my bad, thinking about my dodge.
Old Sep 30, 2012 | 10:24 AM
05PRMTX's Avatar
So got it in with some help from a buddy of mine. They pulley was seized to the pump so we had to take the whole assembly off together. Sprayed some wd 40 on it, let it sit then knocked it on the ground and it finally popped off. Also as a heads up for anyone else doing this, the hose clamps are a huge pain in the *** to get back on, especially the big one on the bottom of the pump. Lots of tension to get it to open wide enough....All in all not too bad though and it works great.
Old Sep 30, 2012 | 08:23 PM
Lime GT's Avatar
That's why you probably needed these... http://toolmonger.com/2007/08/28/s-k...-clamp-pliers/
Mpaps
Oct 11, 2017 08:06 PM
Feb 10, 2017 07:12 PM
Sep 16, 2015 06:44 PM
Beouch
Sep 16, 2015 06:14 PM
eastexsteve
Aug 17, 2015 12:07 PM
