Valve Cover Hell
Old Feb 1, 2008 | 04:40 AM
mustang_lurkers's Avatar
Valve Cover Hell
I bought a set of Steeda powder coated valve covers and am not too happy. I initially thought that the job would be easy but I was wrong. All of the wiring harnesses make it a pain in the but to get the old covers out and put the new ones in. I keep my engine clean but still had to worry about getting dirt into my vavle train when removing the covers. Using masking tape will keep your covers scratch free while putting the new covers in. No instructions were provided so I could see where an excited modder would not think of it. I got the tip by reading forums on valve covers. The biggest thing I didn't like was the fact that the Steeda covers that I got used two less bolts than the factory ones (beware when it says product may vary from one shown in picture) Getting a torque wrench onto all of them is impossible even when using a universal adapter. I couldn't start the car up last night to check for oil leaks because my car is loud and even sounds louder coming out of the garage If they leak I will throw up the flag and just get my factory ones powder coated and put them back in. I sure hope the Steeda covers with two less bolts dont leak though because I don't want to go through with that again . Pics are posted below. I am expanding the IUP color combo into my hood and trunk compartments. Now I need some brushed aluminm under there somewhere.
Old Feb 1, 2008 | 08:00 AM
05fordgt's Avatar
Hey Derek, they look SWEET! Nice color contrast in the engine bay! I did a set about 6 months back. Not the easiest thing in the world to do, but having a second set of hands is a MUST!! My dad helped me on these. Since he's a mechanic with over 55+ years of experience, that made the install a breeze. Took 1.5 hours. But your right, the wiring looms were a PITA! The passenger side was worse than the driver's side.
A tip for anyone who is going to switch their valve covers. Unhook the fuel line. It makes for ALOT more clearance when its not connected. Just use a rag to catch the few drops of fuel. And make sure you unbolt the dipstick. And lastly, a torque wrench isn't necessary. The Ford torque specs are basically what hand tightening equals. My dad told me to "put that d*** torque wrench away", after we got the second covers on, lol. Hand tighening is plenty fine. When you see the gasket flatten out to its max, between the head and the cover, your good!
Old Feb 1, 2008 | 08:35 AM
jcthorne's Avatar
If it makes you feel any better, the GT500 covers are even worse to install. Requires removal of the brake master cylinder and booster. It was quite a job.
Old Feb 1, 2008 | 08:36 AM
Success! I just ran my engine for 30 minutes and had no oil leaks. I checked for visual leaks and any smoking from the headers and there were none. I was very skeptical since Steeda sent me valve covers with two less bolts than the factory covers. Let me know what you think of my color selection.
Old Feb 1, 2008 | 08:42 AM
ren274u's Avatar
Some years came with more bolts than others, i would make sure they sent you right one
Old Feb 1, 2008 | 08:44 AM
Thanks for the compliments Jeff. A second set of hands really would have helped. I guess I am a torque nut to because it really frustrated me when I couldn't get the torque wrench on all of the nuts. I even used a universal joint to get on some of them. I guess it doesn't matter now since I didn't get any leaks. Now I need to get me one of those canton aluminum radiator over flow tanks and some other brused aluminum parts to replicate the IUP and IA (Red) interior under my hood. I did the same thing in the trunk and it looks great as if the whole car came from the factory with coordinated colors everywhere!
Old Feb 1, 2008 | 08:58 AM
jacostang's Avatar
Looks Great! I guess nothing worse while comes very easy....
Old Feb 1, 2008 | 10:57 AM
+1.. the 07+ are different than the 05/06.
btw.. Ford Racing 3-Valve Cam Cover install
Old Feb 1, 2008 | 11:01 AM
GRAYPNY's Avatar
I was going to tell you that ALWAYS check TacoBill's hot links before starting any project. When I installed mine his write was very useful and torquing the bolts is a waste of time and energy.
Old Feb 1, 2008 | 11:03 AM
jayguy's Avatar
I did mine myself, but I also had the entire intake out first to replace the CMCV plates at the same time. I didn't disconnect the fuel line, but once the injectors were pulled out of the head, the whole fuel assembly flips over to the drivers side to get out of the way. And I was able to pull the wiring harness out of the way on each side enough to get the covers in and out fairly easily.
That red does look really good in there, nice job! Wish I had the blower you do to dress mine up even more.
Old Feb 1, 2008 | 11:09 AM
scsmithmh60's Avatar
Looks great, like the color
Old Feb 1, 2008 | 11:13 AM
codeman94's Avatar
I like the red...brings out the red in the Saleen SC!
Old Feb 1, 2008 | 03:43 PM
It looks great!
Old Feb 1, 2008 | 04:09 PM
06GT4RAD's Avatar
Sorry to hear you had such a hard time. I thought the install was very easy to be honest. Those look nice though.
Old Feb 1, 2008 | 06:29 PM
06stage3's Avatar
It's bad with a Roushcharger also. The throttle body sits right over the cover and the cooling lines around the back make it tight.
BTW...I like the red.
Old Feb 2, 2008 | 05:39 AM
Last night I found some torch red powder coated flexible tube radiator and heater hoses. They are going in next. It is time to change the plumbing!
Old Feb 2, 2008 | 08:50 AM
JonCo's Avatar
Looks great
Old Feb 6, 2008 | 10:58 AM
Burke0011's Avatar
Big Falken Tires
Wow - Steeda sold a part without instructions....imagine THAT...
Looks great, man
Old Feb 10, 2008 | 05:25 AM
MUSTANGLOVER73's Avatar
man, that looks good!!! i wish i was that ambitious because i would be out today doing this mod. definate improvement!!
Old Feb 13, 2008 | 07:54 PM
hotairgypsy's Avatar
looks great...i sent you a pm
RCooke08GT
Feb 19, 2017 03:03 AM
lsingggh310
Ecoboost
Feb 7, 2016 12:26 PM
Airborne42
Sep 24, 2015 10:27 AM
BavarianStang
Sep 5, 2015 05:55 AM
