Underhood Hose Dressup
Old 11/26/08, 05:42 AM
SeanD's Avatar
Hi,
I am trying to put together a final list of hoses/clamps to get for my 07 GT. I got an email from someone that got the parts from AMSTREETROD, but I need to know some exact parts for the clamps
Here is what I have so far for parts needed:
#28 - 36" Long (Radiator Hose)
#11 - 9" Long
#7 - 22" Long
#7 - 20" Long
#7 - 15" Long
#7 - 10" Long
#5 - 9" Long
I want to use the Econ-O-Fit connectors that go over the factory connectors. I cannot find a clamps for the #11 hose on the site. Anyone know what will work.
Does anyone have a more exact list of hoses/clamps needed? It would help me out alot.
Thanks,
Sean
Old 11/26/08, 12:04 PM
dly
dly's Avatar
Make sure that list is for a 07 and later as the 05/06 are different for the Radiator Hose. Also don't replace the hose that goes from the lower Radiator expansion down to the lower Radiator hose. You can't see it and it's a pita to get off. I brought my SS hoses from Am, they are a little slow in shipping but good to work with. I would take a picture of my setup but I replace alot when I install my Saleen SC. Let me see if I got a picture from before.
Old 11/26/08, 12:13 PM
SeanD's Avatar
dly,
You wouldn't happen to have your invoice from them for the SS hoses? Supposedly the #28 hoses is for the 2007 engine. I asked AMSTREETROD, and they did not know what parts were needed.
Old 11/26/08, 05:09 PM
dly
dly's Avatar
This is what I found
2' 18 AutoFlex Hose
1' 5 AutoFlex Hose
7' 7 AutoFlex Hose
1' 11 AutoFlex Hose
2 5 EconOfit 17/32" Blue
8 7 EconOfit 21/32" Blue
2 12 EconOfit 15/16" Blue
Also later I purchase 3' -28 Autoflex hose item # 303028 $68.99
2 #18 EconOfit blue 1 3/? #900218
Whats all I could find but I changed over to a Saleen S/C and it makes you go back to a 05/06 style crossover for the Radiator. I also brought some Spectre SS Hose from Pep boys but I don't remember what it was for. Again the best hint I can give you is that, don't change the lower 5/8" hose from the expansion tank to the bottom tee. It was a royal pita.
hopes this helps.
Old 11/26/08, 06:01 PM
SeanD's Avatar
What is the #18 hose for? I have not seen that size referenced anywhere.
Old 11/26/08, 06:55 PM
dly
dly's Avatar
It might be the hose I'm tellin you not to do.
sorry
Old 11/26/08, 07:03 PM
SeanD's Avatar
Ok thanks. I am just going to do the main hoses tht you can see, except for the rad hose. That one right now is just to **** expensive. Maybe next Christmas!
Old 11/26/08, 07:05 PM
SeanD's Avatar
dly,
How do you like the Canton tanks? What is that can for at the end of the hoses coming from the Coolant tank? I have seen most people just put a breather filter on it.
Old 11/26/08, 08:54 PM
dly
dly's Avatar
I like them alot. The Radiator expansion tank I got as a Blem from Canton for $85. The Power Steering tank was $99. The Canton expansion tank has an extra outlet, so I placed an extra piece of SS hoses leading to an soda pop can that had "Whoop A$$" soda in it.
Old 11/26/08, 09:03 PM
dly
dly's Avatar
Here's what my Engine Compartment looks now.
Old 11/28/08, 08:38 PM
SeanD's Avatar
Looks real good.
Old 11/28/08, 09:43 PM
05fordgt's Avatar
This thread REALLY has me thinking. Not to do every hose, but a select few dressed with the SS hoses and blue anodized clamps. Hey dly, can you add to your list, what each of the lengths of hoses you posted up, replace under the hood?
Old 11/28/08, 09:51 PM
FLAstangx3's Avatar
Now you just got to LUV that can of WHOOP-***!! Precious!!!!!
Old 11/29/08, 02:13 PM
dly
dly's Avatar
The below list
2' 18 AutoFlex Hose
1' 5 AutoFlex Hose
7' 7 AutoFlex Hose
1' 11 AutoFlex Hose
Plus I believe I brought a couple of the Spectre 3/8" fuel line kits and I had a old Russell Blue clamp kit that have 3 or 4 different sizes in it.
I guess I need to measure my hoses for the exact length and sizes as I have a whole shelve of left overs. After the S/C install I think I'm down to above 5 or 6 total SS hoses.
Old 11/29/08, 10:45 PM
yur1279's Avatar
great thread. I know there was a similar one a whiela go as well. This sia project I'd def want to do eventually.
Old 12/9/08, 05:29 PM
ILikeBond's Avatar
Attachment 66560
^^ What's with the blue filter on the crankcase?
Old 12/11/08, 11:28 AM
BlueRoush's Avatar
A few pics of my Eng. Bay, I can try and dig up my invoice for the hoses if your interested.
Old 12/11/08, 11:33 AM
Doogie's Avatar
That is one sweet engine bay! All you are missing is some strut tower caps to cover up those rusting strut bolts... like the ones from Midwest Auto.
Old 12/11/08, 12:11 PM
Shotokan1509's Avatar
Are those replacement hoses or slip over covers?
Old 12/11/08, 09:53 PM
dly
dly's Avatar
Just put it on for car shows. Helps make the engine compartment pretty
Quick Reply: Underhood Hose Dressup
