Trunk problem, not opening right away.
Old Oct 14, 2005 | 06:31 PM
Sonic05's Avatar
This isn't a big issue, but the thread will get moved here anyway , sooooooo:
I hit my button, and the trunk clicks, but doesn't open. I wait a few seconds (or more depending on the last time I opened it) and it eventully pops and opens. Even if I use the key it does the same thing. If I want it open right away, I have to grab it and lift up.
I sounds and feels like it is getting stuck on the seal. I tried using silicone on the whole seal, but it made no difference. Does anybody have a suggestion on what I could use to lube the seal or keep it from gluing itself to the trunk?
Old Oct 14, 2005 | 09:27 PM
uofh2005's Avatar
I think the lock needs to be adjusted. Mine was doing this and I included it in a list of things for my dealer to take care of. Works fine now.
Old Oct 15, 2005 | 08:14 PM
tigger199's Avatar
Hi Sonic 05 well the trunk thing is a problem . mine did it i just replaced the trunk latch ford has changed up the partnumber but they sent us the old number but it works like new again
happy trails
Old Oct 16, 2005 | 09:34 AM
MontrealStang's Avatar
Got the same problem. Will get it fixed after I get my car back :angry:
http://forums.bradbarnett.net/index.php?showtopic=36249
Old Oct 17, 2005 | 12:01 PM
Stangarang's Avatar
I have the problem too. I have a workaround, though...once I pop the trunk with the key fob, I push down slightly on the trunk lid and that makes it open up. It's definitely sticking on something, but I don't really feel like taking it in for such a small problem.
Besides, if I took it in, there's always a chance they'll break something else while fixing it
Old Oct 17, 2005 | 01:43 PM
mallorysmom's Avatar
I had the same issue. Spouse put WD40 on it and now it's fine. Dealer looked at it and no change until the WD40 hit it.
Old Oct 17, 2005 | 01:52 PM
05redfiregt's Avatar
I have the same problem, haven't bothered to get it fixed yet.
Old Oct 18, 2005 | 06:35 AM
Boomer's Avatar
Mine does it too...sometimes it takes 1 click...sometimes it takes 10 clicks...or pressure on the trunk.
Old Oct 18, 2005 | 08:16 AM
Fastrack's Avatar
I have this exact issue. I always thought it was just cause the trunk hadn't been opened in a while.
So I guess the latch doesn't have enough power to break the seal. I wonder if some white grease would fix it?
Old Oct 18, 2005 | 11:13 AM
Boomer's Avatar
Yeah I'm gonna try to WD40 it this weekend and see if that helps
Old Oct 19, 2005 | 01:39 AM
GhostGT's Avatar
Originally posted by Sonic05+October 14, 2005, 6:34 PM--><div class='quotetop'>QUOTE(Sonic05 @ October 14, 2005, 6:34 PM)</div><div class='quotemain'>This isn't a big issue, but the thread will get moved here anyway , sooooooo:
[/b]
A second before I was about to turn off my monitor, I saw this thread. This is EXACTLY what happens to me! I click as much as 10 times....and just stand there. It got really unbearable and I've decided to dealer it...after having to click it 10 times 2 days ago under pouring rain...
Good to see its not a big/unique problem.
<!--QuoteBegin-Boomer
@October 18, 2005, 6:38 AM
[/quote]
Yep.. If you press down on it, it opens.
Old Oct 19, 2005 | 06:30 AM
Fastrack's Avatar
With mine it only has the rubber sticking to trunk problem if it's been closed for a week or more. I just left my trunk closed for 2 days, and it popped open.
Now the question I have is how far should the trunk "pop", when working mine opens up about 1/2" max. I'm assuming this is fine.
Old Oct 19, 2005 | 12:45 PM
grrr428's Avatar
Is this a issue?
I mean if you click it, it opens right? It just doesn't pop up? If that is the problem then it's probably suction/vacuum together with the added weight ofthe spoiler. A little WD-40 or rubber dressing should help.
Hey, I'm used to old cars, where with spoilers, you'd need a prop rod to keep them up!
Old Oct 19, 2005 | 12:59 PM
Fastrack's Avatar
Originally posted by grrr428@October 19, 2005, 2:48 PM
Is this a issue?
Yes I'm wondering the same thing, I never thought anything about this "problem" until I read this topic!
Old Oct 19, 2005 | 05:54 PM
Sonic05's Avatar
Ha, I never thought so many people would have the same problem. I'm going to look at mine tomorrow . . . see if something can be adjusted, or lubed. I'll post what I find.
I havn't taken mine to the dealer for anything yet, and don't want to for this. I have been having gas filling problems, but don't want them to mess with it. Then, today, gas goes in fine. I guess it stays away from the dealer.
I think anything that makes me look stupid while trying to use the car is a problem.
Old Oct 19, 2005 | 07:27 PM
GhostGT's Avatar
Originally posted by grrr428@October 19, 2005, 12:48 PM
Is this a issue?
Negative, Sir. I don't think any of us are THAT affected by the heat coming out the car after a hard drive...
It clicks, and nothing happens. It just stays closed.
Old Oct 19, 2005 | 09:14 PM
Fastrack's Avatar
With yours is it only after it's closed for long periods? And is it sticking to the rubber? Maybe I have a different issue...
Can you maybe explain what exactly yours does..
Old Oct 19, 2005 | 10:23 PM
GhostGT's Avatar
I've never actually payed attention as to WHEN it really happens...but I push the open button on the key, and i hear the clicking sound, but the trunk doesn't budge at all. Somethings up with the lock im guessing. I'll press it a few times; sometimes it opens, sometimes it just wont. At that point, I have to PUSH down on the trunk and it releases the latch...
Old Oct 21, 2005 | 03:27 PM
Sonic05's Avatar
I think I may have fixed my problem.
I put a couple thin washers under the springs in the trunck lid. I threaded them out thinking maybe they where adjustable, but they didn't want to stay put unless they where tight, so I just put the washers in so I could tighten them down. I also moved the latch in the trunk just slightly downward (there is no real adjustment). The trunk sat just a tad too low anyway.
After sitting a little over a day, the trunk poped right open. If is still opens after a couple days, I think it will be declared 100% fixed.
I blame cheap design for this one.
Old Feb 20, 2006 | 12:22 PM
rodneylynn1977's Avatar
Mine had the same problem, ford replaced the truck mechanism and it works great now...
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
NC14GT
Sep 10, 2017 04:47 PM
RCooke08GT
Feb 19, 2017 03:03 AM
Sep 30, 2015 07:02 PM
