transmission screaming noise... with video
Old Nov 14, 2011 | 07:35 PM
Cheese302's Avatar
apparently there is some type of backing plate issue, apparently some of had the problem as well i included a video. take a listen and let me know what ya'll think. maybe its something worse.
http://www.youtube.com/watch?v=rvdyMlTnQL8
Old Nov 15, 2011 | 04:22 AM
DaTT(1sK)'s Avatar
That sounds awful. I have no insight for you, but that sounds awful.
Did I mention how awful that sounds?
Old Nov 15, 2011 | 01:10 PM
Cheese302's Avatar
thank you captain obvious. its not like the scared look in childrens faces when i drive by as the car warms up hasnt told me that.
just busting chops, but please if you have nothing to add, keep it to yourself.
Old Nov 15, 2011 | 05:57 PM
ford4v429's Avatar
legacy Tms Member
yikes!
suggest a cheep mechanics stethoscope, might be able to narrow it down a bit...odd how it goes away warm, hopefully not a thrust bearing issue. if youre near due for a oil change, I'd cut open the filter and pray theres not a lot of metalflake in it.
have you looked at the seperator plate behind the oilpan? maybe something hit it and pushed it against the flywheel...
I had a old capri that the starter gear stuck out- it sounded about that bad, but more of a screaming sound...
I dunno if our backing plates have a inspection hole like the older ones did, but I'd take a look. just odd how it quiets when warm...
Old Nov 16, 2011 | 06:46 AM
Cheese302's Avatar
i'll check it, i am 90% certain its from the trans and not the engine. thanks for the input. i have pretty much put the car away for winter already, but might drag it down to the dealer to have them take a look.
Old Nov 16, 2011 | 02:04 PM
DaTT(1sK)'s Avatar
You'll have to forgive me, I spend most of my forum time in an Off Topic forum and forget regular forum etiquette from time to time. Hope it's nothing too serious.
Old Nov 18, 2011 | 11:16 PM
jacostang's Avatar
You said when it warms up it goes away completely?
Old Nov 21, 2011 | 06:33 AM
Cheese302's Avatar
yes, completely gone, and as long as there is some heat in the engine through the day, it will stay away till i park it over night.
Old Nov 21, 2011 | 05:52 PM
jacostang's Avatar
OK , no change clutch in or out? Sounds like The Throw out bearing to me....
Old Nov 29, 2011 | 07:48 AM
Cheese302's Avatar
it doesnt sound anything like previous throwouts i have had go bad on me before. just weird. i think even if it is a backing plate issue, i'll have to drop the trans to fix it properly, so i guess it is clutch time.
who has the best prices on oem clutches? i dont really feel like going aftermarket, because i wont ever make much more power.
Old Nov 30, 2011 | 07:26 AM
DaTT(1sK)'s Avatar
IIRC, aren't OEM clutches way expensive. I priced one out once from Ford and it was like $1500 for the entire kit. I think you can get a better aftermarket clutch kit for half that.
Old Dec 2, 2011 | 03:44 PM
B1STANG's Avatar
I have a 07 GT myself. I had an issue with my car on cold starts with this rattling sound from around the tranny and under acceleration. Turns out theres a TSB that came out 8/10? about it. It would go away when the car was warm. Lucky for me I was still under powertrain warranty. They replaced the plate between the engine and tranny and sound is gone. look up separator plate buzz. I hope this helps
Old Dec 5, 2011 | 09:09 AM
FordService's Avatar
Hey Cheese302,
I definitely agree with your taking to your Ford dealer for diagnosis. Your Service Manager will be in the best position to assist you with this and check for TSBs, Recalls, or warranties left on your vehicle. Also, Please PM me with your VIN, mileage, contact info, and dealer so I can look into this further for you.
Deysha
Old Dec 6, 2011 | 10:37 AM
Cheese302's Avatar
Originally Posted by FordCustomerService
Hey Cheese302,
Deysha
sending PM
Old Dec 7, 2011 | 11:54 AM
sending PM
Got it! I'll get back to you as soon as possible.
Deysha
Old Dec 13, 2011 | 09:09 AM
Cheese302's Avatar
though i still hope i can get ford to help me out with this issue, i think i found the tsb that this is covered under. thinking back, i am pretty sure this issue started early summer, but now people look at me funny when driving down the road in my very nice mustang. i think it scares kids.
http://www.stangnet.com/images/stori...-10.pdf?37e6df
Old Dec 23, 2011 | 09:05 AM
97svtgoin05gt's Avatar
This get resolved?? It sounds like that TSB will be your best friend very soon.
Old Dec 28, 2011 | 11:11 PM
bob's Avatar
bob
Agreed
Old Jan 2, 2012 | 06:39 PM
Buler?
Old Jan 4, 2012 | 01:49 PM
Cheese302's Avatar
no, i havent gotten the car to a dealer yet. Sorry, i initially put this up just around when i usually put the car away for winter.
i would say in two weeks or so i will get it to a dealer. need another paycheck first.
