transmission problem
SEEING IF THIS HAS HAPPENED TO ANYONE ELSE. I HAVE 2005 V6 AUTO COUPE, THIS MORING AFTER DRIVING 15 MILES I STOPPED TO GET COFFEE. WHEN I STARTED THE CAR AND PUTT IT IN GEAR, THE CAR JUST SAT THERE. THE MOTOR WOULD REV BUT THE CAR DIDNT MOVE. IT HAPPENED IN EVERY GEAR INCLUDING REVERSE. AFTER ABOUT 30 SECONDS IT ENGAGED AND NOW SEENS FINE. ANY IDEAS? BY THE WAY THE TEMPERATURE OUT SIDE AT THE TIME WAS ABOUT 40 DEGEES IF MAKES A DIFERENCE AND THE CAR HAS NO MODIFICATIONS. THANKS IN ADVANCE JEFF
<div class='quotetop'>QUOTE(ksstangman @ February 14, 2006, 9:33 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Dealer Time!
[/b][/quote]
Dealer Time!
Take it to the dealer. Also, my dad had a somewhat of a similar problem in his old Mercury Sable. He couldn't shift to any gear. A AAA guy showed up and correctly troubleshut this problem:
In the Sable there is a plastic linkage that sits between the shifter and the transmission. It broke and so my dad couldn't engage any of the gears. Your problem could be related to some "linkage" components getting stuck in cold weather or something like that. However, dealer should be able to see if this is the case or not. Hope this helps.
Rando
Aug 25, 2021 11:12 AM
