Traction control?
Old Dec 8, 2007 | 01:56 PM
lougotzz's Avatar
Traction control?
Do the newer mustangs come with traction control? Or anything to make it better in rain or snow?
Old Dec 8, 2007 | 02:03 PM
MustangLynda's Avatar
With the GT it's standard, with the v6 it's an option.
Best thing for snow is snow tires, at least with the GT (partly because of the difference in the OEM tires). Although others have said they have no problem if they drive with strategy.
Old Dec 8, 2007 | 02:18 PM
ShowGT's Avatar
Get something else to drive is easier, but I know not even has this option.
Old Dec 8, 2007 | 03:52 PM
n8rfastback's Avatar
i drive in the snow in my gt, stock tires.
i have to use the traction control in any type of condensation.
i can get around in up to about 3 inches of snow, but i have to be very careful. much skill is required
Old Dec 8, 2007 | 06:43 PM
Falchion's Avatar
Yeah, I had my tires break loose last week, with just a little bit of water on the road.
I didn't even really give it much gas, but I was making a left turn up a small incline. Even with the traction control on it broke loose and spun. At least I didn't get on the brakes, that would have been bad!
Old Dec 8, 2007 | 06:49 PM
yea, i had a heck of a time in the snow.
breaks loose at any throttle. really gotta go slow.
im usually the one going around other people but not when its nasty out, everyone is passing me.
oh well i need to be humbled every now and then
Old Dec 8, 2007 | 08:34 PM
Rob O's Avatar
+1 I have a V6 and had to order it--you can drive it in slick conditions but you've got to think ahead.
Old Dec 8, 2007 | 09:25 PM
kevinb120's Avatar
Every GT I've had has been a PITA in any kind of inclement weather, but the one V6 I had, an 06 even with TC was near impossible to go anywhere in snow. They have a lot of torque off idle and one wheel drive-not to mention on the right side where its always nastier near the edges of the road. I think the GT's were actually better(although that's not saying much) With the bamachips 93R tune with the hyper-throttle, fuggedaboutit...
Old Dec 11, 2007 | 01:59 PM
mot250's Avatar
Proper snow tires on all 4 wheels, a limited slip rear and PRACTICE.
The snow tires will help with grip on all four corners and should not be any bigger than the stock tires on 17 inch rims.
The limited slip means you'll still be able to move if one of the rear tires is on a patch of ice (with an open rear you get the one-wheel-drive mode where the tire with the least grip sjust spins).
Traction control can be used but I prefer to turn it off and learn how the car handles by taking it beyond it's limits when it is safe to do so (isolated roads, parking lots, etc.) so I know what it will do and what I will do to correct the situation.
The hardest part is making sure you can drive without distractions. I may be old school but I believe traction control should only be used by teenagers, "soccer-moms" and those who don't want to "truly learn" how to drive.
Old Dec 11, 2007 | 03:45 PM
Vermillion06's Avatar
I agree with mot250. a set of four snow tires is the way to go for any car driven in winter conditions. I used Michelin X-Ice's on all 4 corners last winter and had no problems in snow or ice. I just put my winter tires back on last week in preparation for bad weather.
On packed snow or ice I don't use 1st gear at all and brake gently and start braking way ahead of time. I basically accelerate, brake, and steer a lot more gently and smoothly than in dry conditions and I don't have any problems getting around.
Old Dec 11, 2007 | 04:40 PM
2nd yr on the stock tires not the best and not the worst. As stated think ahead be carefull. I don't have the need for a better tire for winter. I am afraid to drive the 2k in the snow.
Old Dec 11, 2007 | 07:14 PM
I don't like how the traction control feels, I think because I'm not used to it and I don't know what to do next as far as controlling the car.
Reading this post has made me realize I did donuts in a snowy parking lot last week with the traction control on
Old Dec 11, 2007 | 09:56 PM
Mackitraz's Avatar
And no matter what, stay defensive! lest all your good driving efforts come to waste as the soccer mom plows into you with her tank-dwarfing SUV...
Old Dec 12, 2007 | 02:20 AM
I-70 west's Avatar
Lets get this straight once and for all
The V6 Mustangs from 2005 up do not have standard or as an option any kind of traction-lok, limited slip, positrac or any other name you could put to it. Your going to have to shell out several hundred dollars to buy and then install the unit of your choice. I did the Ford Performance Parts Traction-Lok and had a reputable shop install it for a total of $700.
Well worth it. Why Ford hasn`t picked up on this is beyond me as factory installation is much cheaper.
When I was shopping for my car I had several different salesmen tell me it was in the traction control option. Not double checking to make sure I was PO ed big time to find out later most salesman areers.
Old Dec 12, 2007 | 05:51 AM
Silverback's Avatar
Mustang + snow = Scary!
Old Dec 12, 2007 | 06:45 AM
Well h*ll I remember discussing this with the sales person when I bought my '05 v6. But I just went to the ford website and "built" a v6 and you're right, no traction control option.
Old Dec 12, 2007 | 08:13 AM
kepfordj's Avatar
lol, I think the car is a hoot to drive in the snow. I get a kick of seeing how far I can push it before the traction control take over.
Old Dec 12, 2007 | 10:03 AM
AWmustang's Avatar
Let's get this right once and for all.
Traction Control (the electronic aid that uses engine management and the application of brakes to control wheel spin) is an option on the V6, it comes with ABS and Active Anti-theft in the V6 safety and security package.
A Limited Slip Differential a.k.a. LSD (brand names: Traction-Lok, PosiTraction) is not available from the factory on the V6.
Old Dec 12, 2007 | 10:44 AM
Darn now I can't call my sales person a stupid liar
Old Dec 13, 2007 | 02:16 AM
I-70 west's Avatar
Thank you, Thank you "say this with an Elvis accent"
AWmustang has just clarified a confusion some people are having here with the terms of traction control and traction-lok.
This isn`t hard people !
