There's a power plug in the center console box?!
Originally posted by blackhat97@May 11, 2005, 11:46 AM
WOW! My battery lasts 4 hours tops. I have an ipod mini, 4th generation. I am DEFINATELY getting that replacement battery! THANKS! :worship:
05windveilbluegt Posted Today, 01:21 PM
which ipod do you have? I have the 2nd generation 20 gig and i put in a battery from this company
http://www.newertech.com/ipod
it's good for 21 hours. In real life use i've gone 1 to 2 weeks without having to charge my battery, they also have replacement batteries for later generations.
worth looking into if your battery is starting to fizzle out. It was easy to change for the 2nd gen also
http://eshop.macsales.com/item/Newer%20Tec...ogy/BIPOD550MM/
it might be harder than mine was as the 2nd gen came apart pretty easily
Thanks Nik , it's the ipod mini. I'll get that battery. I'm not really up to speed on these things. I have one only because they gave one to each employee as a holiday gift last year.
Good luck!
http://www.batteryship.com/htmlos/htmlos.c...3&adsrc=goog108
Originally posted by adrenalin@May 10, 2005, 7:06 PM
So do you know you can at least remove the rubber insert in the cup holder to hold bigger cups. I find that the manual is my best friend
Great place to hide things if you're into that kind of stuff
Originally posted by Danalor+May 11, 2005, 6:06 PM--><div class='quotetop'>QUOTE(Danalor @ May 11, 2005, 6:06 PM)</div><div class='quotemain'><!--QuoteBegin-adrenalin@May 10, 2005, 7:06 PM
[/b][/quote]
Man's best friend will "see" that !
Diode Dynamics
6/12/18 03:26 PM
Diode Dynamics
2/28/18 09:37 AM
AMWill
7/20/15 08:40 AM
