tach issue
Old Aug 19, 2021 | 01:21 PM
texasgt/cs's Avatar
tach issue
Its been a while since i have been one here, but I need some help, driving home the other day my tach quit working, after a little while it started back again. it also seemed to hesitate when taking off from a start when the tach wasn't working. Any ideas
Old Aug 20, 2021 | 04:33 PM
Jaryd21's Avatar
Could be a fuse going or bad wiring. Try checking the wiring to make sure all the connections are good.
Old Aug 21, 2021 | 05:07 AM
Paris MkVI's Avatar
I had this intermittent issue in my '06 as well. It is likely the stepping motor issue, and it's on the board for the dash. There are updated stepping motors for these instruments. I don't know if he's still out there, but once upon a time you could pull your dash cluster, send it to a fellow, and he'd send back a fixed one.
Here's a couple of links that may help you research:
https://circuitboardmedics.com/musta...hoCRTcQAvD_BwE
Old Aug 21, 2021 | 09:09 AM
Jaryd21's Avatar
I believe this is the place https://circuitboardmedics.com/musta...hoCl0cQAvD_BwE
hope this helps
CHolowenko
Oct 27, 2018 12:16 AM
05Blackbeauty
Aug 10, 2007 06:28 AM
