Surface Rust
Old Mar 24, 2007 | 05:55 PM
steevr's Avatar
Surface Rust
Man, it's amazing what the moisture in the air alone can do.
I've had my '07 since last June. It's been stored in the garage since November. This evening I went out to put the Battery Tender on. I noticed the vibration damper and the exhaust manifolds were now totally covered with surface rust. The car has never been in the rain.
Rear axle still looks as rust-free as the day I brought it home. Strange....I would have thought that would have had it too.
More proof not to keep it in a vacuum sealed trophy case but rather just drive it to enjoy it.
Old Mar 24, 2007 | 07:01 PM
theedge67's Avatar
Vibration damper? Not sure exactly what you are talking about there...please elaborate or pics??
Old Mar 24, 2007 | 07:08 PM
karman's Avatar
I think he means the harmonic balancer.
Old Mar 24, 2007 | 07:27 PM
DynamicmustangGT's Avatar
It is supposed to have surface rust on the exhaust manifolds its consider discoloration and not rust
Old Mar 24, 2007 | 08:37 PM
RobK's Avatar
He's probably right, it's likely surface rust. As stated, the best way to keep a car in good shape is to use it. The only thing better is a 100% heated and/or cooled garage.
Old Mar 24, 2007 | 08:46 PM
SteelTownStang's Avatar
"That" surface rust will not hurt anything. Believe me... it'll out last you.
Old Mar 24, 2007 | 09:10 PM
RobK's Avatar
Yep, seals the iron so it can't oxidize any further.
Old Mar 24, 2007 | 09:34 PM
kevinb120's Avatar
Yup, they still should of painted or treated the rear axle housing though.
Old Mar 25, 2007 | 07:31 AM
metroplex's Avatar
AFAIK Ford has never painted or sealed/treated the rear ends on any of their cars. The trucks and vans that get Dana rear-ends usually have a black paint/treatment (most likely done by Dana, not Visteon).
Old Mar 25, 2007 | 11:19 AM
GirchyGirchy's Avatar
Are you positive it's rust on the headers? It might just be discoloration from high exhaust temps. I work at a diesel engine plant where a small percentage of the engines go through a 2.5 hour test. After this, the exhaust manifold, turbo, and EGR cooler, and even the stainless bolts are all darkened from the heat. It looks like it's rusty, but it's not.
As for the damper, yeah, it's the same as the harmonic balancer. Those terms can be used interchangeably.
Old Mar 25, 2007 | 11:27 AM
KdF's Avatar
KdF
Word!
It`s made of cast iron....rust is inevitable. You could always wipe it down with some oil , but it won`t last.
Old Mar 25, 2007 | 11:34 AM
metroplex's Avatar
A harmonic balancer is used for externally balanced crankshafts (like on a 5.0/302 SB V8). A harmonic dampener is used for internally balanced crankshafts, such as the ones used in the modular engines. I've never heard the term vibration dampener used to describe the harmonic dampener/crankshaft pulley before.
Old Mar 25, 2007 | 02:10 PM
scramblr's Avatar
Oh yeah, it's rust. No different than the rest of the underneath of the car...
Feb 10, 2017 07:12 PM
JonsMustang
Mar 5, 2016 05:44 PM
robjh22
Dec 14, 2015 08:41 AM
bones302
Oct 7, 2015 04:42 AM
DrVet
Sep 23, 2015 01:48 PM
