Steering play
Old Dec 12, 2019 | 02:04 PM
SleepingBear's Avatar
Steering play
Did a quick search on the matter, if it already exists just send a link.
I got a small steering play in my wheel when I turn maybe 10-15 degrees the wheels don't turn. Is this a common problem with the stang? What would be the first part to look at, steering shaft?
Old Dec 12, 2019 | 11:13 PM
houtex's Avatar
That really doesn't sound normal. These are tight and quick steering racks on these cars. If you've got that much play, it sounds like you've got a problem somewhere, and *all* of it is suspect.
I'd be thinkin' your rack is the problem, but it could be the steering shaft. Heck, could be the steering wheel itself, although I really really doubt that. There's an outside chance is a tie rod end, but it doesn't sound like it. In any event, you'll want to have someone turn the wheel while you inspect things, and probably from underneath, having put the car on jack stands and chock the back wheels.
Old Dec 13, 2019 | 02:33 PM
Bert's Avatar
yeah 10-15 degrees is a lot . . . how many miles are on the car?
my first thought was badly worn tie rod end(s) but could be the rack itself . . . let's hope it's the tie rod end(s) because they are a lot cheaper and easier to replace
Old Dec 17, 2019 | 09:33 AM
Will begin to check rack and shaft then.
It has only done 25000 miles. (41000km)
Old Jan 27, 2020 | 09:24 PM
mrkabc's Avatar
So what happened? Bad rack? Bad tie rod ends? Bad ball joints? 2005/2006 were known for very weak ball joints, something to check out.
Old Jan 28, 2020 | 05:23 PM
Cavero's Avatar
Any clunking? Any steering wheel shake on the highway?
wawanesamuscle
Jun 19, 2014 10:57 PM
Mystang68
Aug 16, 2013 07:10 PM
les
Jun 6, 2012 10:46 PM
redpony05
Nov 8, 2011 05:05 PM
Wardog 07
May 30, 2006 08:55 AM
