Steeda Replacement Shifter Linkage Bushings - 05-10
Old Aug 3, 2012 | 10:37 AM
SteedaBrandon's Avatar
Former Vendor
Arrow Steeda Replacement Shifter Linkage Bushings - 05-10
Mustang Replacement Shifter Linkage Bushings - 05-10 - $29.95
Please let me know if I can help you with this.
These bushings go bad on the stock shifters and Ford won’t sell you these bushings without buying an entire shifter! Our's are also more durable than the stock ones.
Steeda's replacement shifter bushings are designed to reduce slop that develops over time with your aftermarket or factory shifter caused by the shifter linkage bushings wearing out.
The OE replacement bushings are not available from your Ford dealer separately, they can only be obtained by purchasing an entire shifter assembly. Our bushing are more durable, direct replacement upgrades.
Manufactured from high-strength plastic to provide a more direct link to the transmission. Does not require removal of the entire shifter assembly for installation.
Product Benefits
  • High strength plastic reduces shifter slop
  • Prevents purchasing the entire OE shifter just to replace the worn out bushings
  • Does not require any permanent modifications to car
Old Aug 3, 2012 | 11:22 AM
Planeswalker's Avatar
Just get the Tri-Ax, one of the best mods you can get!
Old Aug 6, 2012 | 10:18 AM
SteedaGus's Avatar
We appreciate that comment! However the Tri-Ax re uses the factory bushings for the linkage that these bushings replace. The Tri-Ax does not come with replacements and Ford doesn't sell them separately, only with a complete factory shifter assembly can you get these and that is a huge expense for just bushings.
Here is a view of where they go.
Old Aug 6, 2012 | 07:54 PM
Zaksgt's Avatar
We're can I get a shift ball that fits your shifter for the 05-09, kinda sucks not being the stock thread size
Old Aug 7, 2012 | 10:09 AM
Technical Note: Compatible with stock GT shift ****; stock **** is not threaded but has a nylon insert which grabs the threads when twisted on.
Never tried to re-use the stock one, but got this tech note off of AM. Any shift **** made for Mustangs from 1979 to current should work.
Old Aug 7, 2012 | 11:56 AM
Former Vendor
It fits the stock shift **** and we also make some shift ***** for it.
You can view shift ***** here: http://www.steeda.com/store/ford-mus...d-handles.html
Jul 8, 2016 08:53 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
Sep 2, 2015 07:33 PM
