Sppedo reading
Old Mar 28, 2011 | 12:22 PM
Dineau's Avatar
Sppedo reading
On our mustangs, is the speed calculated at the front or rear wheels ?
I'm asking because why installed my new tires they have a difference in Rev/miles from front to back because I have larger wheels in the back.
The difference is minimal. The original OEM tire/wheels are 766 Rev/mile and if I compare my new wheels/tire in the fronts are (770 Rev/mile) which means 0.52% too fast and the rear are 752 Rev/mile) which is 1.78% too slow.
I'm wondering which value should I enter in my SCT to make sure my speed rating is accurate on the Speedo.
I know it's only 1.78% in the worst case and that means that I will actually be a bit faster than the speedo if the rear is being use.
My guess is that I should use the rear tires/wheel valus as I think the car uses the transmission rotation to determine speed but with all the fancy electronics and ABS sensors I was wondering where the calculation come from ?
Thanks,
Old Mar 28, 2011 | 12:26 PM
05YellowGT's Avatar
The rear wheels ...
Old Mar 28, 2011 | 03:15 PM
G Wrecks's Avatar
Originally Posted by 05YellowGT
The rear wheels ...
Old Mar 28, 2011 | 06:08 PM
Dineau's Avatar
Old Mar 29, 2011 | 12:33 AM
ETNOATS's Avatar
Even after I used what was supposed to be the revs mine was off compared to my GPS. So I kept adjusting to match.
Old Apr 5, 2011 | 07:39 PM
Cavero's Avatar
Use the tire manufacturers spec. There was another thread on this. We concluded the car's computer does actually match the GPS speed, it's the instrument cluster that's off. I confirmed it by using the datalog on my SCT tuner with my laptop.
May 3, 2026 05:42 AM
Cobiecane
Oct 23, 2015 08:44 AM
Bryanh24
Oct 14, 2015 08:43 AM
DerekShiekhi
Sep 30, 2015 06:59 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
