Shifter sticking??
Old May 2, 2013 | 11:15 AM
05PRMTX's Avatar
Shifter sticking??
I have an 05 V6 5spd. Lately it has been a real ***** putting it in 1st gear. It doesnt grind or moan but I have to push really hard most of the time.Like it just doesn't want to pop in there. Rest of the gears are fine. Maybe somthing with the shifter itself? Idk, seems like an odd problem. Anyone else have this issue or know what it could be?
Old May 4, 2013 | 04:56 AM
Beargap's Avatar
I would suspect the slave cylinder is going bad. Have you checked the clutch master cylinder fluid level?
Old May 6, 2013 | 03:13 PM
05PRMTX's Avatar
No I havent, good idea. I will do that tonight,Thanks
Old May 7, 2013 | 11:11 AM
05PRMTX's Avatar
So checked the fluid. Its still pretty much full...
Old May 7, 2013 | 11:12 AM
muscledom's Avatar
Needs a clutch
Old May 8, 2013 | 11:24 AM
05PRMTX's Avatar
Probably. Its not that bad though
Old May 8, 2013 | 11:28 AM
muscledom's Avatar
Depending on the miles it could just be the syncros wearing out too
Old May 9, 2013 | 11:03 AM
05PRMTX's Avatar
Its about 81K
Old May 9, 2013 | 11:38 AM
muscledom's Avatar
Originally Posted by 05PRMTX
Its about 81K
Yea it could be in the tranny. My GT has 90k very hard miles on it and it does some interesting stuff lol
Old May 12, 2013 | 10:00 PM
Lime GT's Avatar
You might try checking for trans fluid leaks and checking the fluid level. Have you ever changed the trans fluid yet? Fresh Mercon V may help with the syncros.
Old May 13, 2013 | 04:47 AM
ford4v429's Avatar
legacy Tms Member
royal purple synchromax worked wonders on my tranny- kinda damaged the 2nd synchro redline shifting at the track, wouldnt go into second at alll about 1/3 of the time...put up with it for a year, on advice of someone in here tried the RP, and viola- like a new transmission, and its no exaggeration- this stuff is amazing.
that was several years back, after many more harsh trips to the track, its starting to get a little balky again, but only in that sometimes it refuses to go into reverse, have to put in first, roll fwd, then reverse- but its still tolerates redline shifting...53k and im due for a clutch- it disengages clean, so dont think its causing the reverse issue, but it wont bark 3rd anymore, and has had a slight chatter when cold a few times- so assuming its worn/glazed a bit from abuse...its to the point i think next time to the track we might be pushing it home
I'd strongly suggest you try the RP before tearing into the tranny, its due for a change anyways right? stuffs like 15 a quart or something like that, but worth every penny IMHO. if i ever start driving our 09, guarantee soon as it gets a few hundred break-in miles it will get RP before ever seeing the track...I'm certain had I run RP before abusing my 06 it woulda likely prevented the original synchro issues- just amazes me oil could 'fix' -yeah, mask really- a mechanical/wear issue.
tim
Old May 13, 2013 | 12:55 PM
05PRMTX's Avatar
Thanks for the advice guys. No I havent changed the trans fluid on it. I will check the levels and look into changing the fluid.
Old May 13, 2013 | 01:32 PM
muscledom's Avatar
For the record I have royal purple in mine and it made zero difference. From what I hear the best is Redline ATF
jim010
Jun 24, 2024 04:23 PM
Jul 8, 2016 08:53 AM
Sep 16, 2015 06:44 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
