Shifter Help 2007 Gt
Old Dec 2, 2007 | 09:04 PM
muslenutz's Avatar
I Drove My Friends Cobra And He Had A Short Throw Shifter In It And I Was Stalling Like Crazy And Missing Gears With It. Now As I Drive My Stock 07 Gt I Cant Stand The Shifter. I Need Something New, Any Suggestions On What I Might Like Or Need?
Old Dec 2, 2007 | 09:21 PM
RadBOSS's Avatar
All the shifter kits have reduced leverage. That results in shorter shifter travel at your hand, and slightly more effort. The after market shifters are generally closer tolerance in the mechanism, so there is slightly less slop. Despite all this, the shifting action is all still controlled inside the gear box. That is where the shift gates are, they are not in the lever mechanism you shift the gears with (or replace). There are as many opinions as to what is the best one as there are shifters available. Do a search in the GT forum and you will find your answers (recommendations).
Old Dec 3, 2007 | 06:04 AM
05YellowGT's Avatar
MGW
Old Dec 3, 2007 | 07:58 AM
Hurst makes a good shifter.
Old Dec 3, 2007 | 08:00 AM
FLAstangx3's Avatar
First of all, an R-Code is a totally different animal. Your problem was not the shifter so much , as is the difference in the clutch. However I think we all, here anyway, would recomend upgrading the shifter to either MGW, Hurst, TriAxe or Pro 5.0 for some examples. That'll at least get you started. Very easy install, and you'll be able to bang some shift's with the stock clutch. If you get serious into it, eventually, after some engine mods, you'll need to look into centerforce or others. Your not going to be able to duplicate the Cobra. That is the one thing I do miss most with my S-197, over my R-code. But the trade off's were worth the switch, to me anyway.
Old Dec 3, 2007 | 09:50 AM
acascianelli's Avatar
Hurst makes a good cheap shifter, but with the Hurst the shifts are meant to be notchy. MGW also makes a good but expensive shifter, the MGW will be a very smooth shifter.
I love my Hurst.
Old Dec 3, 2007 | 09:51 AM
Robbieg's Avatar
I have a steeda Tri-Ax and I like it.
Old Dec 3, 2007 | 10:04 AM
NYNY53's Avatar
MGW
Smooth, quality, delite to use in a daily driver.
Old Dec 3, 2007 | 11:56 AM
Cheese302's Avatar
i have a hurst, might switch to mgw because i am going back to a stockish ****. the only two i would reccomend are hurst and mgw though
Old Dec 3, 2007 | 12:30 PM
mrkabc's Avatar
MGW Shifter. Daily driver here - I absolutely LOVE the shifter. George makes an A-1 product.
Old Dec 3, 2007 | 01:53 PM
scramblr's Avatar
I've gone from stock to having the Saleen adapter, to a Pro 5.0 to the MGW. MGW by far is the superior shifter IMO.
Old Dec 3, 2007 | 06:32 PM
ronslakie's Avatar
Short Throw Shifter
I have the MGW and it is great. I do not believe there is another shifter out there that gives you the versatility that the MGW has. Besides excellent quality of materials, you can adjust the length of the shifts and adjust the shift handle either right or left or up or down.
Old Dec 3, 2007 | 06:44 PM
I love the Hurst shifter I have, but then again its the only I have tried. I went with it for looks and have really enjoyed the feel. You are right, the all things to all people stock shifter is sloppy to say the least.
Old Dec 4, 2007 | 05:40 AM
metroplex's Avatar
The stock shifter is like rowing a boat, but I've gotten used to it.
Old Dec 4, 2007 | 06:40 AM
NYNY53's Avatar
Row baby row..........................
Hey more power to ya if stock works for you
Old Dec 4, 2007 | 01:33 PM
SkyMaster19's Avatar
MGW =
Old Dec 4, 2007 | 02:11 PM
officespace56's Avatar
Hurst Comp daily driver here. It breaks in nice and I picked it up for a good price from subzero.
jim010
Jun 24, 2024 04:23 PM
Jul 8, 2016 08:53 AM
AdPock
Oct 16, 2015 02:58 PM
Sep 16, 2015 06:44 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
