Shelby Razor hubcentric Rings
Old Jan 8, 2010 | 04:48 PM
vegasfish's Avatar
For all that have the 18x9 Shelby Razor wheel, do you need Hubcentric rings or are the lugs good enough for centering the wheel.
Old Jan 8, 2010 | 06:19 PM
Lugs fer sure. Rings not needed. Use a tq wrench!
Old Jan 8, 2010 | 06:21 PM
Oh by the way Welcome to TMS! Post a pic of your ride.
Old Jan 8, 2010 | 10:19 PM
bob's Avatar
bob
Are the wheels lug or hubcentric?
Old Jan 9, 2010 | 06:19 AM
vegasfish's Avatar
Tire Rack is showing required lug nuts specific and Hubcentric rings????
Old Jan 9, 2010 | 09:18 AM
They are lug centric. Do a search on here there are several threads about this. I had a slight wooble problem and tried the rings they were no help. Aftr the problem was solved I took the rings back off and felt no difference at all.
Old Jan 10, 2010 | 06:50 PM
bob's Avatar
bob
Yeah, if they are lug centric then hubcentric rings dont really bring much to the table. More importantly, you need to make sure that when the wheels are balanced the shop doing so is using a pin plate of some sort to simulate the wheel being located by the lugs on the car, if not, there may be balancing issues.
Old Jan 13, 2010 | 08:22 AM
20" Razors here.
Old Sep 27, 2010 | 07:38 PM
JadeCrew's Avatar
---yup you need hubcentric spacers to center the wheel. my cousin tried it before and it work for alot for him. you should try it too.
Old Sep 28, 2010 | 10:01 PM
908ssp's Avatar
I would never buy wheels that aren't hub centric. Lug centric just doesn't work and if it does for you you got lucky next time you bolt on the wheels it may not. The lugs are simply not made accurate enough. Getting the wheels off center relying on the studs is stupid. Sorry I thought people knew this already amazing after all these years of crap wheels not locating properly companies still sell lug centered wheels. Yes rings of good quality will work there are junk rings out there beware.
Old Sep 29, 2010 | 05:07 AM
Riiiiiigggggggggghhhhhhhhht
CoyotePremium13
Oct 7, 2015 07:17 PM
Detroit Steel
GT350
Sep 3, 2015 07:50 AM
