Shaker Bad Disc Solution
Originally posted by Daniel1981@June 16, 2005, 11:48 AM
Does anyone have any tips on how to avoid the 'Bad Disc' response from the shaker?
I take the disc out and either rub it on my shirt or pants and reinsert it. Works everytime.
Originally posted by ISELLFORD@June 16, 2005, 11:56 AM
I get this message every so often on a disc that i had already played [always happens with MP3's that i burned].
Ed,
That is what I am experiencing. The first time I insert the CD it will usually play fine, but then when I return to that cd the second or 3rd time, it will spit it out with a BAD DISC error.
I would like to avoid having to re-insert the disc everyitme.
I wonder if I higher bitrate would avoid the bad disc.
Also, Nero is kind of hosed on my computer.
Is anyone using cd-burning software that is NOT Nero, and that doesnt give the Bad Disc all the time?
I found this TSB in the local thread here:
"Replace CD player with latest service level through your facing audio service center"
I wonder, what is the current service level for the Shaker 500? Maybe replacing it will remove the 'Bad Disc' error.
I've had bad disc on both MP3's and store bought CD's. I usually reload and it works fine. Pain in the you-know-what on the MP3's, especially if I was on song 50 out of 110. Only a couple of times has it read as a bad disc and spit back out. But on the 3rd try it would work.
It normally happens to me when I've started my car up, or if I've put in a disc right before turning off the car, and then started it back up a short time later.
BTW, I never had problems until I started reading the threads about people having these issues. Oh well, what am I going to do about it?
Just to chime in here.
I have a March 27 built car and I have not had the error once.
I have MP3's and standard CD's.
The only thing that the shaker has done is locked up on me kind of.
When I turned the volume up it went down and when I turned it down it went up. I powered it off and then on and it's been fine ever since.
I would take them back to the dealer and demand that they be replaced.
I would use this forum as a reference to people who don't have any problems.
Good luck all.
Good luck all.
I also make a point to hit the AM/FM Radio button below the CD button to change to regular radio before I turn the car off after playing CD's.
I've only had the bad disk error message 2 times in 6 - 7 months of use. I just unloaded the CD and reload it, works fine again.
i got an 05 mustang at the end of april, have had no problems with the shaker 500 system, and then suddenly this morning i was changing cds and it jammed. the clock stopped, and all it displays now is DS F1 T50. i just went out to check it now and it sounds like there is a fan going to try to cool it down inside the sound system display. does anyone have any idea what to do?!?! all the dealers near me are closed... please help me!! u have to understand this is my baby!!
Did you try it again after you powered off the car?
Try diconnecting the battery. That might reset it. The noise you hear may be the cd changer looking for a disc.??
Good luck.
I got my Shaker replaced, works much better now. The new one did spit out a disc once so far, but hasn't happened since. Maybe it was just the disc that caused that one. The problem happened much more often before the replacement.
thanks very much for the insight. i disconnected the battery and it seemed to stop the problem. also i took it to the dealer and they said they are going to call me and they will replace the system anyway. thanks again!!
Rando
8/25/21 11:12 AM
tacbear
9/27/15 12:57 PM
