Shaker Bad Disc Solution
Old Jun 16, 2005 | 11:45 AM
Daniel1981's Avatar
Does anyone have any tips on how to avoid the 'Bad Disc' response from the shaker?
Old Jun 16, 2005 | 11:53 AM
ISELLFORD's Avatar
I get this message every so often on a disc that i had already played [always happens with MP3's that i burned].
I take the disc out and either rub it on my shirt or pants and reinsert it. Works everytime.
Old Jun 16, 2005 | 12:03 PM
yur1279's Avatar
I have had the bad disk problem only a handful of times, usually I get the sudden skip sound. I have found that if i burn a data disk of mp3 files off my comp, then I have no skips and no bad disk messages. When I have had the bad disk message, I press the load button and the disk has alwasy read fine afterwards.
Old Jun 16, 2005 | 12:10 PM
Daniel1981's Avatar
Ed,
That is what I am experiencing. The first time I insert the CD it will usually play fine, but then when I return to that cd the second or 3rd time, it will spit it out with a BAD DISC error.
I would like to avoid having to re-insert the disc everyitme.
Old Jun 16, 2005 | 12:13 PM
SixtySix's Avatar
Shut the unit off for a few seconds and then back on and see if that clears it. I've never had the bad disc error but that works on the few occasions it skips on me.
Old Jun 16, 2005 | 03:44 PM
Daniel1981's Avatar
I wonder if I higher bitrate would avoid the bad disc.
Also, Nero is kind of hosed on my computer.
Is anyone using cd-burning software that is NOT Nero, and that doesnt give the Bad Disc all the time?
Old Jun 16, 2005 | 03:51 PM
Daniel1981's Avatar
I found this TSB in the local thread here:
"Replace CD player with latest service level through your facing audio service center"
I wonder, what is the current service level for the Shaker 500? Maybe replacing it will remove the 'Bad Disc' error.
Old Jun 16, 2005 | 05:30 PM
AZOmae's Avatar
I've had bad disc on both MP3's and store bought CD's. I usually reload and it works fine. Pain in the you-know-what on the MP3's, especially if I was on song 50 out of 110. Only a couple of times has it read as a bad disc and spit back out. But on the 3rd try it would work.
It normally happens to me when I've started my car up, or if I've put in a disc right before turning off the car, and then started it back up a short time later.
BTW, I never had problems until I started reading the threads about people having these issues. Oh well, what am I going to do about it?
Old Jun 16, 2005 | 05:31 PM
ponyboy66's Avatar
Just to chime in here.
I have a March 27 built car and I have not had the error once.
I have MP3's and standard CD's.
The only thing that the shaker has done is locked up on me kind of.
When I turned the volume up it went down and when I turned it down it went up. I powered it off and then on and it's been fine ever since.
I would take them back to the dealer and demand that they be replaced.
I would use this forum as a reference to people who don't have any problems.
Good luck all.
Old Jun 16, 2005 | 06:08 PM
TN615's Avatar
get the shaker B...
i have to do that soon too...
it is a tsb
Old Jun 16, 2005 | 06:16 PM
mlcrisis's Avatar
I've burned all of my MP3 CD's at the highest bitrate possible and record the CD's at a SLOW Speed (2X - 6X). (You don't get near as many songs on a CD, but the audio quality is much better). Use Roxio Easy CD Creator software.
I also make a point to hit the AM/FM Radio button below the CD button to change to regular radio before I turn the car off after playing CD's.
I've only had the bad disk error message 2 times in 6 - 7 months of use. I just unloaded the CD and reload it, works fine again.
Old Jun 17, 2005 | 04:45 PM
bigfoot1141's Avatar
I had a store bought cd that the Shaker would only read the first song then skip over the rest of the disc. Really wierd!
Old Jun 22, 2005 | 08:32 AM
GhostTX's Avatar
I'm getting this problem now. Store bought and MP3 CD. Tried the shirt thing, the power thing and I have 'B' as the last letter in the diagnostic.
Old Jun 22, 2005 | 09:47 AM
adrenalin's Avatar
Solution, keep going back to the dealer and have it replaced until they get one that works....or....get an aftermarket head unit installed.
Old Jun 26, 2005 | 11:02 AM
luvmymustang05's Avatar
i got an 05 mustang at the end of april, have had no problems with the shaker 500 system, and then suddenly this morning i was changing cds and it jammed. the clock stopped, and all it displays now is DS F1 T50. i just went out to check it now and it sounds like there is a fan going to try to cool it down inside the sound system display. does anyone have any idea what to do?!?! all the dealers near me are closed... please help me!! u have to understand this is my baby!!
Old Jun 26, 2005 | 01:46 PM
ponyboy66's Avatar
The display to me appears to be D(5) disc 5, F1 Folder 1, and T50 track 50.
Did you try it again after you powered off the car?
Try diconnecting the battery. That might reset it. The noise you hear may be the cd changer looking for a disc.??
Good luck.
Old Jun 26, 2005 | 02:36 PM
frdtch05gt's Avatar
I got my Shaker replaced, works much better now. The new one did spit out a disc once so far, but hasn't happened since. Maybe it was just the disc that caused that one. The problem happened much more often before the replacement.
Old Jul 4, 2005 | 06:49 PM
thanks very much for the insight. i disconnected the battery and it seemed to stop the problem. also i took it to the dealer and they said they are going to call me and they will replace the system anyway. thanks again!!
Old Jul 5, 2005 | 08:01 AM
Dineau's Avatar
I know it has been post many times, but how we get the Shaker to display it's revision # ?
Old Jul 5, 2005 | 08:15 AM
GhostTX's Avatar
AM/FM and hold the 3 & 6 at the same time.
Rando
Aug 25, 2021 11:12 AM
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
GLOCKer
Sep 28, 2015 05:20 PM
tacbear
Sep 27, 2015 12:57 PM
