Shaker 500 / 1000 Diagnostics and Speaker Test Mode
Speaker Walk-Around Test
NOTE: To enter the speaker walk-around test or audio unit self-diagnostic mode, the audio unit must be on and in radio tuner mode (AM/FM).
NOTE: To enter the audio unit self-diagnostic mode, the audio unit must be on and in radio tuner mode (AM/FM).
- To enter the speaker walk-around test, simultaneously press and hold the audio unit preset buttons 3 and 6.
- The speaker walk-around test stops at each speaker and applies sound to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the audio unit in the following sequence: RF, LF, LR, RR, and SUBWOOFER.
- To exit the speaker walk-around test, turn the key to OFF, turn the audio unit off, or press preset button 1 for diagnostics (DIA).
- To enter the following tests, press the desired preset button while in the speaker walk-around test.
- To exit the audio unit self-diagnostic mode, turn the key to OFF or turn the audio unit off.
- The self-diagnostic mode has the following functions available:
- Preset button 1 = On-Demand Self-Test. This button runs the on-demand self-test.
- Pressing the MENU DOWN button allows scrolling of any DTCs found during the test while in this menu.
- Preset button 2 = Display Continuous DTCs. This button enables viewing of any continuous DTCs that have been logged.
- Pressing the MENU UP button allows scrolling of any DTCs while in this menu.
- While continuous DTCs are being displayed, pressing the EJECT button will clear all present DTCs. The key must be cycled OFF, then ON, to permanently clear DTCs.
- Preset button 3 = Signal Strength Test. This button displays the signal strength.
- Preset button 4 = Software Version Display. This button displays the audio unit software version.
- Pressing the MENU UP button allows scrolling of all audio subsystem software versions while in this menu.
- Preset button 5 = Display Test. This test illuminates all the display segments for 5 seconds, then either turns all segments off or indicates DISPLAY TEST on the screen.
- Preset button 6 = Configuration Status. This button enables audio unit configuration status.
- Pressing the MENU UP button displays the ACM part number while in this menu.
- To exit the self-diagnostic mode, turn the key to OFF or turn the audio unit off.
