Sequential turn signals
Old Sep 13, 2019 | 03:57 PM
fiftyslost's Avatar
Hi all. I have a 06 base that I installed sequential wiring kit. They blink faster than I would like. I realize the flasher is integrated in the SJB. Does anyone know if dealer can change the speed to have a little longer pause between flashes?
Old Sep 13, 2019 | 05:34 PM
Spree's Avatar
No, You can't
Old Sep 13, 2019 | 06:04 PM
fiftyslost's Avatar
Originally Posted by Spree
No, You can't
Not what I wanted to hear. Thank you for responding.
Old Sep 13, 2019 | 11:15 PM
JimB.'s Avatar
What kit did you buy ? I had the same issue with the kit that I bought from AM. I changed them out this spring with a kit from Scott Drake. They are programable. I have mine set on the slowest setting and the sequence is much ore defined. Not as good as the 2013 and newer cars but much better than it was. I also have the coyote tail lights and that helps some also. PM me and I can text you a video. I tried to attach it here but I can not make it work.
Old Sep 14, 2019 | 06:48 AM
fiftyslost's Avatar
Thank you JimB for responding. I do have the Drake kit and have it set to the slowest setting. I like the flasher speed of the newer Mustangs. Nice car you have. Thanks again.
blkstang06
05-09 Exterior Modifications
Sep 1, 2007 09:21 PM
Emperor008
28
Aug 10, 2007 08:49 PM
dustindu4
May 20, 2005 09:10 PM
GhostTX
Mar 28, 2005 12:26 PM
s197sb
Oct 19, 2004 09:40 AM
