Rev Limiter
I tell ya, I hit the rev limiter today for the first time and man, is that a kill-joy. The engine shows no sign of tiring when it comes in either. You're just enjoying a wave of great thrust...when suddenly....BLAAA. She quits. I'm pretty used to driving these cars by feel and sound, thing that's different with this one is that when it kicks in, the motor shows no sign of giving up.
I can't wait to see more posts about how well the bottom end holds together with a higher rev limiter. I want to raise mine to 6800 (shifting at 6500 max), but I AM a bit leary of sending a powder cracked rod through the side of a once nice aluminum block!
Long term, it won't be a problem because I want to build a fully forged crank/rods/pistons rotating assembly for it so I can port the heads, but a bigger cam in and raise the rev limiter up to around 7500 or so. But until then, I REALLY don't want to ventilate the block!
Once you have a tune, the peak HP is from 5900-6300 rpm.
Originally posted by TwoBlackStangs@February 27, 2005, 10:19 PM
Someone once told me the computer logs each and every time you hit the rev limiter so the service dep. (read: bye bye warranty) can pull that information if they want. Anyone confirm this?
everytime you hit the rev limiter, it sets a code without putting on the check engine light. no, it does not void any warranty. that's what it is there for - to protect the engine.
the technician won't even call attention to it unless there is engine damage related to abusive driving. so if you hit the rev limiter once in awhile, its not so bad.
Go ahead and program it out ..... Don't come back here female ******* when you blow an engine ....
Or better yet, learn your car .... You should be able to "hear" where you have to shift without even looking at speedo or tach.
I want to meet the person thast gets any warranty work denied for hitting the reve limiter .... Rev limiter is there to protect the components ....
On manuals, the rev limiter is set at 6000 rpm. I'm not sure about autos, maybe the same.
I've hit it once too... and it is a "party pooper"... you're right that the thing still seems to be pulling strong when it hits... I'm more aware of my RPMs now when I goose it.... But for the most part, I drive like the 42 year old I am... BTW, I've had the same experiance on my Buell Lightning... and when a bike hits the rev limiter it can actually be scary - it's almost like rear brake is applied unexpectedly...
The rev limiter is not a killjoy, it's an hiney saver!
If you accidentally (or on purpose for some reason) rev past 7000 on these motors, you'll get valve float and probably piston to valve contact, and you'll get to buy a new motor.
Now THAT is a killjoy.
Beef up the springs and you can spin it a lot higher, but there is a LOT of stress on wrist pins & bearings at high speeds...probably best to wait for a built shortbloack before revving to the moon.
holderca1,
The reason people are getting better times shifting at 5500 instead of 6k is BECAUSE of the rev limiter and how it is implemented on the 05. The engine is closing the throttle as you approach the rev limit and it takes it a half second or so to reopen it. By shifting earlier, you stay in "control" of the throttle instead of the ECU overriding it for you. If you raise the rev limiter, you can shift at the right point for power and not have the ECU second guessing you.
Cobiecane
Oct 23, 2015 08:44 AM
