Replacing underhood hoses & flexikool heater hose?
#41
Originally Posted by nole_trainer
rtleslie, thanks so much, I already ordered the other hoses from pepboys, I will order the radiator hoses from amstreetrod. Do you think they will match?
Oh yea, by the way your engine compartment is what I printed for my edumacation....
Done - Jay was great to order from, he spoke highly of your set-up
#44
OK, my covers are on the way back to me - finally. On both of the PCV's, do you use the clamps that are on the original hose, or do I use my blue ones? Trying to get everything ready for the install, maybe Tuesday or Wednesday of next week!!
#46
Originally Posted by Stoenr
The drivers side 90 degree one I kept, the rest I used the hose clamps
#47
#48
Does anyone sell ready cut braided steel hose kits along with locks/caps, etc?
being all the way across the atlantic, it would take me years to get it right, if i'm to order one part at a time and go on a trial and error spree :S
#50
Originally Posted by G.T
come on guys, someone please help me find a ready cut hose kit, or at least post your hose measurements
http://forums.bradbarnett.net/showpo...88&postcount=2
#51
Originally Posted by rtleslie
#53
Would a kit like this work??
http://www.powerflowracing.com/spect...ail.asp?PD=636
Can someone pls refresh the links at the begining of this post.
#54
#55
Links refreshed...
First go here, http://www.powerflowracing.com/spectre-catalog.asp and select "Plumbing". Determine all the part numbers needed and then to Autozone web site. You can probably walk into an Autozone and pick up this whole kit and the fittings will be red and blue. I only wanted blue fittings so I bought the hoses and fittings seperately.
Each hose kit comes with 2 fittings (these are the blue and red ones)
5/16" line: http://www.powerflowracing.com/spect...ail.asp?PD=756. It's 48" long and you cut it to the size you need and slip the other clamp on. Need one of these.
3/8" line: http://www.powerflowracing.com/spect...ail.asp?PD=762. It's 36" long and you cut it to size also. Need two of these, and use the excess from one of them for the brake vaccum and buy an extra set of clamps.
5/8" line: http://www.powerflowracing.com/spect...ail.asp?PD=827. This one is 48" long and you cut it to size also. Need one of these as well.
The radiator overflow, passenger side PCV, fuel vaccum, and brake vaccum are 3/8", the fuel rail one is 5/16", and the big PCV on the driver's side is 5/8".
#56
Follow scramblr
Originally Posted by scramblr
Links refreshed...
#57
Originally Posted by traffic142
They are great. I know they are not "real" braded lines, but it looks really good when you pop your hood.
#58
Links refreshed...
Just be warned with this, if you have a different CAI that requires a longer passenger side PCV you may not have enough. Like the JLT intake.
#59
Donna, I see you made it work with the JLT, what gives? you buy 3 hose kits vs 2?
No...but, I might not have hose somewhere else that you do. I bought everything from this thread and took it to my mechanic. He gave me back quite a bit of leftover...
