Replacing underhood hoses & flexikool heater hose?
Ok, how the heck did you get the drivers side pcv connector seperated? I notice everyone still used the factory 90 degree connector.
I for the life of me cannot get it seperated from the hose
hah ok, never mind, just REALLY had to pull HARD
Dang....Missed your edit. LOL
Ok, all done. But with one disapointment.
Not enough hose left to do the overflow tank hose.
I used more with the JLTII intake to PCV. It requires more hose length, leaving me short on the tank hose
But I do have enough left over with Chrome ends for someone to do the fuel rail, and brake vacuum lines.
I have enough hose without ends for the big drivers side PCV.
Willing to trade for some 3/8 to do the overflow bottle.
Donna, I see you made it work with the JLT, what gives? you buy 3 hose kits vs 2?
Originally Posted by traffic142
Did you cut away the hose from the 90 deg fitting on the drivers side using a razor blade?
Originally Posted by nole_trainer
Newbie question here, is there a kit to do this? If not could you guys/gals hook me up so I don't have to re-do what you've already done. I want the blue connectors....
First go here, http://www.powerflowracing.com/spectre-catalog.asp and select "Plumbing". Determine all the part numbers needed and then to Autozone web site. You can probably walk into an Autozone and pick up this whole kit and the fittings will be red and blue. I only wanted blue fittings so I bought the hoses and fittings seperately.
Each hose kit comes with 2 fittings (these are the blue and red ones)
5/16" line: http://www.powerflowracing.com/spect...ail.asp?PD=756. It's 48" long and you cut it to the size you need and slip the other clamp on. Need one of these.
3/8" line: http://www.powerflowracing.com/spect...ail.asp?PD=762. It's 36" long and you cut it to size also. Need two of these, and use the excess from one of them for the brake vaccum and buy an extra set of clamps.
5/8" line: http://www.powerflowracing.com/spect...ail.asp?PD=827. This one is 48" long and you cut it to size also. Need one of these as well.
The radiator overflow, passenger side PCV, fuel vaccum, and brake vaccum are 3/8", the fuel rail one is 5/16", and the big PCV on the driver's side is 5/8".
THANKS, I saw that post earlier, but it didn't make sense. But it does now that it's put together with my question. The scary thing is that I actually uderstand what it means (after taking my cam covers off for poweder coating). Will post pixs in a few weeks!! Trying to get all this new stuff done before new baby comes, and my first show in October......
Originally Posted by hags1
The radiator hose in the left picture I attached is size 24
The radiator hose in the right picture I attached is size 28
hags1
hags1
What radiator hoses/clamps did you use? Sizes? Thanks....
Here's the list:
List:
Perform-O-Flex:
# 24 - One hose 12" Blue Anodized Fittings - Econ-O-Fit
Auto-Flex:
# 28 - One hose 16 1/2" - Blue Anodized Fittings - Econ-O-Fit
# 7 - One hose 22" - Blue Anodized Fittings - Econ-O-Fit
- One hose 20" - Blue Anodized Fittings - Econ-O-Fit
- One hose 15" - Blue Anodized Fittings - Econ-O-Fit
- One hose 10" - Blue Anodized Fittings - Econ-O-Fit
# 5 - One hose 12" - Blue Anodized Fittings - Econ-O-Fit
# 11 - One hose 9" - Blue Anodized Fittings - Econ-O-Fit
rtleslie, thanks so much, I already ordered the other hoses from pepboys, I will order the radiator hoses from amstreetrod. Do you think they will match?
Oh yea, by the way your engine compartment is what I printed for my edumacation....
Done - Jay was great to order from, he spoke highly of your set-up
