Replacement of auto trans shifter
Old Dec 28, 2013 | 01:11 PM
Pauls02's Avatar
Hi, need to replace my auto trans shifter with an oem on 06 mustang GT, already have console out and am awaiting arrival of new shifter, my question is can this be done with out getting under car and all from inside? Here is what part looks like. Thanks Paul
http://www.ebay.com/itm/NEW-OEM-5R55S-AUTOMATIC-TRANSMISSION-GEAR-SHIFT-LEVER-2007-2009-FORD-MUSTANG-/231071167273?pt=Motors_Car_Truck_Parts_Accessories&hash=item35ccea3329&vxp=mtr
Old Dec 28, 2013 | 03:26 PM
Sese's Avatar
It is a fairly simple swap done from inside. No need to get under the car. I had mine done in less than an hour with basic tools. Just go slow and take a picture of the existing shifter once you have the middle console open.
And this might help for the console:
https://drive.google.com/file/d/0B9O...it?usp=sharing
Old Dec 29, 2013 | 06:12 AM
Pauls02's Avatar
Here is photo with it off. I removed the 4 bolts one on each corner, but what's the trick to get tranny linkage shifter unbolted from underneath ? I can't seem to pull it far enough up into car to do that. Does it have to be done from under?
Old Dec 29, 2013 | 11:55 AM
akdoggie's Avatar
I found it easier to go under and undo the special connector for the shift cable linkage. That's how I went about the cable. The shiftrt then just lifts out and you replace it. Go back under and hook up the clip. That way you are 100% sure of the linkage adjustment. JMO on how I did mine. Good luck.
Old Dec 30, 2013 | 05:07 PM
Pauls02's Avatar
That's my answer. Was looking for a way to do inside but I didn't think it possible
Jul 8, 2016 08:53 AM
GrabberBlue310
2012-2013 BOSS 302
Sep 17, 2015 08:21 AM
Road_Runner
Sep 10, 2015 01:14 PM
Road_Runner
Sep 10, 2015 11:28 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
