Re-setting Check Engine light?
Old Jul 20, 2008 | 04:27 PM
Northwest GT's Avatar
Must have not had the gas cap completely socked down. The gas gauge quit and the warning came on about low fuel. The check engine light came on as well. Tightend up the cap and everything went back to normal except the check engine light is still on. Does that need to be reset by the dealer?
Old Jul 20, 2008 | 05:19 PM
MTAS's Avatar
If you don't have a hand-held tuner to do it yourself, take it to AutoZone or a similar place - they should have a scanner and can clear it for you, usually at no charge.
Old Jul 20, 2008 | 06:09 PM
Thanks - Will do.
Old Jul 20, 2008 | 06:16 PM
catman's Avatar
My CEL came on almost immediately when I swapped out the stock gas cap for a locking one that I had purchased from KC about two years ago! Disconnecting the negative ground on the bat for about 15 minutes to reset the computer did the trick.
Old Jul 20, 2008 | 06:25 PM
maucoin65's Avatar
Legacy TMS Member Retired
Did the locking gas cap give you any more trouble after that??
Old Jul 20, 2008 | 09:00 PM
catman's Avatar
None--life has been good for three months and numerous fill-ups!
Old Jul 20, 2008 | 09:03 PM
GottaHaveIt's Avatar
You could disconnect the battery and wait 1 min rehook to reset. opps already said with regards to locking gas cap I had an 05 GT now an 07 GT/CS never an issue for me @ all
Old Jul 20, 2008 | 10:46 PM
Lime GT's Avatar
I think the EVAP system should do another check for vacumn leaks after a few starts. If it reads everything ok, it should clear the loose cap code. At least mine did.
Ecostang
Nov 3, 2022 08:50 PM
STOERKEL
Sep 11, 2015 11:38 AM
ClayP
Aug 11, 2015 06:23 AM
Will3212
Jul 16, 2015 10:30 AM
