qick question about the fascia
sorry if this is a repeat post but have not seen it mentioned so had to ask. Why do the newer pics show that the lower grille on the fascia is now filled with a black plastic insert as opposed to the older pics and pics in the order guide and promotional pics that show body color painted spreaders and no black inserts? will there be some sort of option as to which way you would like as i would like the colored(as i would like colored mirrors of course) also wondering why they may have chosen to change this small feature?
I'm sure you will be able to take that black insert out, and you will have the body-colored bars there. But, like Kevin said, Ford put it there to control airflow, so might just be better to leave it. When I get my car, I'll take it off and see how it looks. If it really looks a lot better, I might take it out. Gotta way my options at that point.
Originally posted by Wombert@August 31, 2004, 10:39 AM
The insert is not black enough for my taste. It has this cheapy-plastic-black color... the two "closed" inserts just look odd
Surely there is a way to cut out the airflow restricter from the black insert and mount it from the inside.
Originally posted by Galaxie+August 31, 2004, 6:38 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Galaxie @ August 31, 2004, 6:38 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Wombert@August 31, 2004, 10:39 AM
Case and point (this is EXACTLY what you'll see on the production version - even with the same holes filled in):
I'm not a car expert myself. What - if any - drawbacks to performance would there be if the fascia insert were removed? Would it have a serious or negligible impact? I ask since I think it looks better without the insert.
Thanks,
-J
Thanks,
-J
