Pypes Mid-muffler system sound clips
Old Sep 17, 2007 | 05:57 PM
aircare84's Avatar
Finally got a few short clips posted of my Pypes Mid-miffler system. They are short,as I don't have the time to edit video, but will give you an idea. Stock manifolds,H-pipe,Pypes from there on back.
I've got short clips of a start-up,drive by,cruise with windows up & down.
Put the pieces onto 1 video,see my post below.
Old Sep 17, 2007 | 06:08 PM
GRAYPNY's Avatar
They sound great but I have heard that the fitment is terrible. Comments?
Old Sep 17, 2007 | 06:35 PM
aircare84's Avatar
Rich,
Too many pieces to replace the stock from H-pipe to axle back. I've tweaked it for about a week & half now, finally gotten where I'm happy with it. The R/H side tail piece hanger rods need refined. I had to heat up the hanger rods & bend them a bit to fit the hanger brackets.
The quality is good, the tips & mufflers are nicely polished & the pieces fit well togther.
As for the sound, I think I'll keep it. Different than running the GTA's, but it does have it's pluses.
Keeping the GTA's for when I get around to installing those LT's
Old Sep 18, 2007 | 05:27 AM
Silverback's Avatar
It sounds great!
How long did the install take? Tips?
Any drone inside the cabin? What about heat issues as the mufflers are moved inboard w/o any heat shielding?
Can you tell I am about to buy this set up?...
Old Sep 18, 2007 | 03:51 PM
aircare84's Avatar
O.K., I had a little time & patched all the clips + some,only 1 clip now;
http://www.youtube.com/watch?v=fANDdIp2GjY
Rich,
I didn't answer you accuratly last night. The fitment is NOT terrible, at least in my case. Actually fairly good. The 2 areas that could be better are the 2 pipes from the 'H' to the new mufflers should have had a slightly less angle on them,as the clearance to the tanks is tight, but the clearance to the driveshaft is plenty, I think they should have bent the 1st piece a little less. The only other area is the hanger brackets on the last pipe should be moved about a 1/2" forward. That is the piece that replaces the original muffler.
I bent the hanger rods on mine to fit better. The main reason I've been tweaking it is due to my nature of being a perfectionest,probably wouldn't be an issue to most of the normal folks out there. But, most here are probably like me too.
Silverback,
I do have some drone @ 2100rpm, nowhere else.Very minor & even tolerable for me.I hate drone. As for tips, I posted a write-up on the install on;
http://www.mustangforums.com/m_3836473/tm.htm
Heat should not be a problem, it appears the tanks themselves have a plastic shroud on the bottom, so that should help keep the muffler heat from the actual fuel tanks.
Sep 10, 2015 12:44 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
