Punching through the firewall....>>
Has anyone drilled a hole in the firewall for routing wiring? I'm wondering where the easiest / best location is.
There is already a spot to run wires thru it. On the passenger side behind the wheel well(plastic cover) there is a huge rubber grommet there that you can snip the tip off of and run plenty of wire thru.
